Decals for the Ronald Reagan
    November 2008
Posted by Arespontus on Friday, May 21, 2010 2:06 PM
Hello
I want to redo my USS Ronald Reagan 1:720. In order to do so though I need to get decals for the aircraft carrier. Does anyone know where I could get them.
Thank you,
Scott
    April 2004
Posted by keilau on Saturday, May 22, 2010 4:54 PM
Arespontus
I would think that the kit manufacturer should be the first place to try. Revell has very good replacement parts policy and easy to order from their site.
If you have the Italeri kit, let us know whether you have any luck ordering parts from them or MRC, the US distributor.
If you don't have any luck with the manufacturer, you can try Starfighter decals. They have the 1:700 desk decals for almost every Nimitz class except the Ronald Reagan. The Nimitz class decals are actually 1:720 scale which should be perfect for the Revell or Italeri kits.
    March 2004
Posted by Mikeym_us on Monday, May 24, 2010 7:29 PM
Gold Medal Models makes a 1/700 scale Supercarrier decal set for ships from the USS Forrestal to the USS George H.W. Bush. You would need that set anyways for the correct size flight deck edge numbers. And the Ronald Regan is a Italeri kit.
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    March 2005
Posted by mfsob on Wednesday, May 26, 2010 9:31 AM
I hae used both the Gold Medal Models and Starfighter Decals carrier decals sets and they are both good - they fit well, snuggle down into the recesses tight, and look good once clear coated.
