Airfix Vosper MTB
    December 2003
Airfix Vosper MTB
Posted by sisu on Monday, August 9, 2010 12:55 PM
This is a blast from the past.  I bought this kit more than a couple of years ago and now that I have the time, I'm going at it.  The four-piece hull looks like I will need six hands to put together.  Does anyone who may have built this kit have any suggestions on the best way to go about it?
    February 2007
Posted by 2/20 Bluemax on Monday, August 16, 2010 12:26 PM
I built mine in the late '70's. I dry fitted using tape and rubber bands until I figured I had it right, then applied plastic glue. I now use small drops of CYA strategically placed for temporary fitting to get things right. When I'm satisfied with the fit, I glue up,  using tape, rubber bands and plastic glue or solvent (for strength).
Jim
    August 2008
Posted by tankerbuilder on Saturday, September 11, 2010 4:50 PM
Hi, when I built mine(and I have another to build) I did it this way.First the sides and transom. Then the two halves of the bottom. This cuts you down to two pieces of hull parts you have to handle.Let these units dry well BEFORE trying to bring the bottom and sides together. Once you,ve done this the rest is a neat build.ENJOY   tankerbuilder
