"That's my story, and I'm stickin' to it." Jeff, sounds like your usin' too much CA
Thanks guys. Just wanted to be sure I don't screw up my first tall ship!
Sounds like I should keep doin' what I've been doin'. In my woodshop...
Titebond II yellow glue is what I use for furniture joints.
TIP:Dampen (do not saturate) the wood first to open the pores then apply the glue. I use a fine mist spray bottle.
Elmers white glue being a polyvinyl acetate (PVA) drys clear and works for many applications where strength is not the primary concern.
TIP: A color pigment (you can get it from art supply sotres) can be added before application to achieve the desired color so that painting is not required.
CA, I've found works well on plastics and those types of material.
TIP: Use a sewing needle - eye end - to apply for tacking. The eye will hold a very small amount then when touched to another surface it will "wick" onto the other surface.
I use
contact cement to apply flexible materials to a hard surfaces, such as fabric or carpeting to wood.
I use
epoxy to adhere metal to wood such as brass knobs to drawer faces etc.
I've seen "Gorillia" brand glue but haven't tried it.
I haven't had too many gorilla's to glue back together recently.
I went to www.gorillaglue.com and read up on their product. Sounds good. I'm going to get some next time I go to my local DIY and try it.
Via Google search engine I found pics of Ambroid cement. What is the skull and crossbones caution?
I hadn't thought of using acrylic gel as a filler. I know some artists use it in their paints. Sounds like a good idea. How do
you apply it, with a dental tool, flat toothpick or ??
"I use 30 minute epoxy." Is there a specific reason to use 30 minute vice say 10 minute which is what I've been using? Or do you just have more patience than I.
I've stayed away from Tenax 7R as it is MEK (methyl ethyl ketone) based.
QUOTE: From Air Toxics Website
Methyl ethyl ketone is used as a solvent. Acute (short-term) inhalation exposure to methyl ethyl ketone in humans results in irritation to the eyes, nose, and throat. Limited information is available on the chronic (long-term) effects of methyl ethyl ketone in humans. Chronic inhalation studies in animals have reported slight neurological, liver, kidney, and respiratory effects. |
I have asthma and the inhalation of MEK does my lungs in. I also have a neurological issue that they think may be caused from extended exposure to MEK when I was younger. My brain cells are dying at a faster rate than re-growth. My doctor, at Barrow's Neurological Institute (BNI), told me that I should expect my name to be called up yonder in about 5 years. NO violins please! I plan to finish my train layout, the Flying Cloud kit I just purchased and scratch build the USS constitution before roll-call.
I haven't used cotton string for any of my projects and the mention of beeswax made me start thinking of rigging line. Should
all rigging line be waxed? If so, does the white glue hold waxed line okay or should the rigging be waxed after stringing? What does the beeswax do for the line?
