IJN heavy cruiser Suzuya 1939
    September 2010
Posted by potchip on Thursday, October 7, 2010 10:02 PM
Re-classified as a heavy cruiser after installation of bigger main guns following Japan's withdrawal from the Washington naval treaty.
Built as she appeared in 1939 after the last major refit just pre-war.
Posted by Anonymous on Thursday, October 7, 2010 10:10 PM
Nice...one of my favorite classes of ships..what scale, what kit?
    September 2010
Posted by potchip on Thursday, October 7, 2010 10:21 PM
Good old Tamiya in 'divine scale' Stick out tongue For ships, there's only ever will be one scale.
Some in-progress shots:
A more up-to-date set of shots with added signal lights, wind direction finder and canopy brackets
    March 2004
Posted by subfixer on Friday, October 8, 2010 8:10 AM
Very nice! What is with the transverse lines on the deck? I'm not familiar wth this.
I'm from the government and I'm here to help.
    January 2003
Posted by p38jl on Friday, October 8, 2010 10:01 AM
very sweet..! Smile
[Photobucket]
    September 2006
Posted by the Baron on Friday, October 8, 2010 12:07 PM
Nice job of detailing, right down to the access rails around the stack, boy, are they delicate!
Did you paint the deck, or is that a decal?  The Japanese used a linoleum covering, didn't they?  Are the "stripes" seams, or were they painted on as some kind of markings?
Best regards,
Brad
Posted by Gamera on Friday, October 8, 2010 12:42 PM
Wow, she looks beautiful! I have a few ship kits in my stash but all that rigging and teeny PE parts always scare me off. Kudos sir!!!
    September 2010
Posted by potchip on Saturday, October 9, 2010 7:26 AM
Hiya subfixer/the baron, those are metal strips used to secure the linoleum covers on the deck. On the kit, the deck has moulded raised line to represent these but it would be very difficult to paint these ultra thin lines gold after the main deck coat, so instead I used brass wire cut to length and glued on afterwards. The wires are a bit too thick, however any thinner and they will be difficult to keep straight. There are also PE replacements of these by fine molds/joe world but they are prohibitively expensive. The linoleum deck is just painted with Tamiya linoluem colour.
The most difficult part of the build was actually the float planes and their rigging between the wings/on floats. This was not intended as a very involved build from the outset but I got carried away mid-way. Otherwise I would've replaced the main masts with thinner brass tubes as the kit part is a bit too thick scale-wise.
Posted by Tojo72 on Saturday, October 9, 2010 2:21 PM
very impressive detailing,she captures that very menacing look of an IJN Cruiser,great posting
    December 2009
Posted by Harshman II on Sunday, October 10, 2010 10:27 AM
Superb!!!  It is always difficult to do PE on 1/700 scale. I already quit that scale since it spoil my eye sight.
    March 2006
Posted by TD4438 on Monday, October 11, 2010 2:23 AM
I love it.I also wish I could do half as well.Maybe some day.
    March 2007
Posted by JMart on Monday, October 11, 2010 8:33 AM
Very well done; superb job on the rigging and deck detailing. The only thing I would add is to bore out the armament (or get metal barrels; I just got some RB metal barrels for the german pocket BBs, very cheap for 700 scale).  While the pin vase is out, maybe bore out the portholes even though is a major pain. What did you use or how did you make the on deck "stuff"?  Again, great job! cheers
    September 2010
Posted by potchip on Monday, October 11, 2010 7:20 PM
Thanks folks for the kind words. I did bore out the main gun and 12.7inch barrels (though the 12.7 are too thick for scale, typically skywave. Had they been in scale I wouldn't be able to drill them properly). Again the portholes were also slightly 'deepened' to kit stock.
This was originally intended as a quick build but ended up just piling on things. However I made no corrections/pre-planning other than 'pile on' PE so the end result is somewhat in-consistent. It helps that the Tamiya kit is very well engineered and friendly to superdetailing, eg, between the levels of the bridge, a square opening is already opened up to easily put in included ladders, and the bridge space is already hollowed out, all I need to do is cut away the windows etc. Overall it took about 3 weeks to 90% completion then many weeks after as the laziness sets in.
Used the following bits and pieces...many are just scrap pieces lying around.
Lionroar:
generic ladders, inclined ladders, bridge windows
triangular gaussets, solid and perforated
landing light from carrier nets set
thermal baffle for 203mm guns
IJN hand rails, doors & hatches
type 96 twin AA, 13mm twin AA
anchors/fairleads/life rings/chrysthanthemum
degaussing cable, boat davits set III
aircraft set, air direction radar, ammo crates
crew figures, IJN cable reels, IJN perforated bars
aircraft handling rail and turntables, IJN catapaults set
Flyhawk:
Float braces from the USN battleship set for the float planes
Machine guns from the USN airpower set 1 for the float planes
Tom's:
crane/search light platform support from IJN heavy cruiser set
ariel mast on turrets
Pitroad:
boats, type 89 AA (shielded type)
Fujimi:
search light in clear plastic
Other:
extra fine chain
sandbags from putty
wood bundles from 0.2mm sheet plastic
wires of various thickness
bits and pieces of white decal paper for railing canvas covers - deployed or rolled up etc
Hull plating from from masked primer coat (horizontal only, no vertical plates/weld lines)
Posted by tigerman on Wednesday, October 13, 2010 10:45 PM
Superb build. I love IJN cruisers and yours is one of the nicest I've seen.
 Eric
