warshipguy
Cap'nMac,
I would like to hear more about your resume paper technique!
Bill
Ok, I had tried actual cloth, sewing seams and the like, adding doubling, the whole bit--just not practical much below 1/32 or so--and the scale factor works against you too.
I tried my "flag" technique, which is to use silkscreen fabric--which is very spiffy for flags, especially using dye-sublimation printers--but the silk is too fine for sails. It's floppy, and pretty expensive, too.
For in the 1/80 to 1/120 range, I'd tried newsprint, crumpled and wetted and allowed to dry to form. This was good, but looked too much like a single sheet of oatmeal.
Enter felicity. Some wet towels and some 100% linen rag paper comingled. When dry, the linen texture was still there, and the paper had not lost its "vellum like" look, either. Neat.
Even better, you can scribe details, like seams using colored pencil. Spray starch will help hold a curve (and will coerce fine thread reef points to lay down, too). Under 1/100 or so, you can use a printer and a sepia or gray tone to print details on the paper. Going up from 1/96, you can use a strip cutter and glue doublings, reef bands, the like on the sails.
A dab of woolite and water seems to help the sheets as you get in the 1/48 -1/16 range (other problem being in sails that fir the sheet size). Doubling and bands glue--they want a pounce wheel to show stitching, but the thickness is so very nice.
