lookig for DE model --- leyte gulf time frame - samual b roberts - or of same scale
vmi1966 lookig for DE model --- leyte gulf time frame - samual b roberts - or of same scale
Same scale as what?
In 1:700 you can find a Butler-class DE from PitRoad.
In 1:350 things get more difficult, you will have to mingle a couple of kits to get there; The ISW Rudderow will be the basis (low-bridge DE) and you'll have to find a suitable replacement stack. I'm thinking the Trumpeter/PitRoad joint venture Cannon mod of the Buckley is the source of the stack. Plus a few other minor swap-outs. Or start with the Trump/PitRoad Cannon and cut down the bridge and find some donor 5"/38s
in 1:192 scale Blue Jacket makes a wood, white metal, & PE Sammy B.
1/249 Buckley Revell
1/350 USS England Trumpeter
Want to make the Abercrombie for a neighber. What do you suggest? Can I kitbash using Trumpter kits of USS England and ? The England is a Buckley Class and I need a Butler Class. Any suggestions?
Thanks, Dane
http://www.bluejacketinc.com/kits/butler-class.html
dane alley Want to make the Abercrombie for a neighber. What do you suggest? Can I kitbash using Trumpter kits of USS England and ? The England is a Buckley Class and I need a Butler Class. Any suggestions? Thanks, Dane
EdGrune <<SNIP>> ... I'm thinking the Trumpeter/PitRoad joint venture Cannon mod of the Buckley is the source of the stack. Plus a few other minor swap-outs. Or start with the Trump/PitRoad Cannon and cut down the bridge and find some donor 5"/38s
