Water Putty vs. Milliput
    March 2010
Posted by Bocks Suv on Monday, January 17, 2011 12:09 PM
I just stumbled onto Durham's Water Putty at the hardware store. It's dirt cheap but how does it stack up to Milliput or other coupounds?  I want to reshape the bow of an Airfix Schnellboot and considering these options as well as sheet styrene, etc.  How has Water Putty worked for you (adhering, sanding, painting)?... and what's the best Milliput version to go with if that's my better option.  Thanks.
    November 2008
Posted by plasticjunkie on Monday, January 17, 2011 12:36 PM
I've been using Durhams for years for ground work only. Like you said, its cheap and does a great job when mixed with Elmers glue to make sure it stays put on the wood base.  I don't think it will be as good as the milliput when it comes to adhering to plastic. The white milliput will give you a smoother finish fthan the other colors  when blending it to the plastic.
 GIFMaker.org_jy_Ayj_O
    January 2009
Posted by Division 6 on Monday, January 17, 2011 1:16 PM
Instead of Milliput you would be better off with Magic Sculpt or Aves.
Folks that do Garage kits say that are smoother and easier to work with.
I use Magic Sculpt but when it runs out plan to try Aves since it is supposed to feather on the edges better, both can be smoothed out with water or Aves has a Safety Solvent that can be used instead.
