This weekend saw the hull sanding complete and the anti-fouling paint applied. I found a few spots that needed another hit of 600 grit love. I now just have to refresh those areas and give the hull another coat of anti-foul red/brown. I use Tamiya XF-64 Red-Brown. For the Bismarck I added some straight red to bring the color more reddish. I'm happy with the color as anti-foul always changed colors with sea life, debris, oil and other things floating in the ocean. The stack and superstructure seams have been tamed and I had to add some Tamiya liquid filler to some seams here and there, most notably the deflectors on the 2 deck superstructure side which are the boiler air intakes. I added these after gluing the surrounding parts in place when they probably should've gone in during deck attachment. The small boats are pretty much ready for their PE and paint.
I posted on another thread some info on how I made the blast bags for the turrets. Following paragraphs are a paste from that thread located here:/forums/t/135485.aspx?PageIndex=2. Thanks to Manstein's Revenge for starting that thread, I found some good info from his thread and hopefully returned some info for others to use.
I used Tamiya Expoy putty which was
pretty simple to use. I cut off about 1/4" of each slab of material,
kneaded the two parts together until the color was consistent and took a
pinch off and mashed it into the gun hole in the turret. The turret was
a spare from the Bismark kit but it turns out that there were no spare
barrels so I just glued a bit of styrene sprue to the turret to simulate
the barrel. The epoxy material looks to be about the right color as
well so I might just leave it as is.
I used water to keep the epoxy from drying out and keep it soft. I
just kept adding little chunks here and there until things looked right
size wise then I slowly pushed the epoxy blob towards the lower portion
of the barrel to simulate the extra material that hangs down below the
barrel. I then intentionally left some deep finger prints here and there
for the lines that occur in the canvas material and randomly scribed
some deeper lines here and there. The effect came out really good and
I'm pretty happy with the first shot. Now to do this on the real thing
after the turret paint is done and before the PE goes on. I compared my work to the bags that come with the Dragon Scharnhorst and the color and look is right on :-)
Here are some pics:
[View:/themes/fsm/utility/
:550:0]
:550:0]
:550:0]
:550:0]
After I finish the hull red and it cures for a couple of days I'm going to spray the hull gray and complete the boot line. Then I start on the deck details and attaching superstructure components.
PS: The Eduard PE kit comes with a template to drill a series of U shaped holes, 3 wide on the side of the hull under the water line under the Anton turret. The instructions recommend to check your references but with all of the books and info I have on the Bismarck I can find no info. Does anyone know what there are for? I was thinking about something to do with ice since the ports can freeze up but I would assume that there would be many more if this were the case.
Thanks
