Dying rope
Dying rope
Posted by gawga on Sunday, February 20, 2011 8:29 PM
Has anyone tried to dye rope for a model?  I lost points on a model in a contest because the rope wasn't a "hemp" color.  The funny thing is, the windings on the end binding the thimbles are real hemp and the rope it is wound on is cotton - both the same color.  What a laugh.  First of all, what is "hemp" color generally understood to be?  Second, would a soaking in tea or coffee approximate the desired color?  Other suggestions welcomed.  By the way, this isn't rope used in a nautical setting, but I thought someone here would have a good idea to  steer me in the right direction.  Thanks.
Posted by millard on Sunday, February 20, 2011 11:26 PM
I usally dye my rope with and india ink solutions. I use a small pill bottle but about twenty drops of india ink in then fill the rest with denatured alcohol. I then but the rope in the bottle let it soak for ten to fifteen minutes. Take out then run it through a paper towel to wipe off the excess.Then run it through my bees wax and its done.Hope that helps.
Rod
    August 2005
Posted by EdGrune on Monday, February 21, 2011 6:07 AM
gawga
An overnight  soak in tea would be good,  coffee may be too intense.
A trick I learned when I was tying my own fishing flies was to make a 'tea' of onion skins,  boil them up and let them cool.  Then dump in a handful of feathers and allow them to soak.   They take on a nice amber-brown color.
Posted by gawga on Monday, February 21, 2011 6:37 AM
Ed,
Just out of curiosity, how did you happen to hit on onion-skins?  Most unsusal.
    August 2005
Posted by EdGrune on Monday, February 21, 2011 7:09 AM
Its an old recipe among fly-tyers.
Posted by Don Stauffer on Monday, February 21, 2011 8:42 AM
Hemp is kinda tan to light brown.
    October 2005
Posted by CG Bob on Monday, February 21, 2011 6:00 PM
I've used wood stain and Kiwi boot polish (paste type in the tin) to dye white line.    I read that the tannic acid in tea and coffee can slowly erode cotton line.
Posted by gawga on Monday, February 21, 2011 6:57 PM
CGBob,
That was the basis of my original question that coffee/tea might have that effect.  My problem is at this time that the rope is assembled to the thimbles and parts so using a polish or some such isn't an option.  Since the parts are metal, I thought the dip in coffee/tea was feasible but possibly with long time effects.  What I will probably do is to dilute an acrylic paint significantly to dip the assembly in after testing the end color on another piece of twine.  Suggestions anyone?
    September 2007
Posted by SuppressionFire on Monday, February 21, 2011 7:22 PM
Try any sewing supply shop and buy the right color thread!
I  have spools in various colors and thicknesses to serve in different scales and applications. Even bought fine black & silver thread to be used as crane cables on a 1/144 scale Dora rail gun.
One trick to remember is to pass the thread over wax (ordinary candle will work) to eliminate fuzz & stray strands.
Here is thread used to tie down stowage on a Sherman. No glue warranted nor required as the tie down lugs are metal CA glued from the hull interior:
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
Posted by gawga on Monday, February 21, 2011 7:50 PM
Suppressionfire,
I appreciate what you recommend,  however that isn't an option.  My error, I should have added that my model is scratch built in 1/8"=1inch scale and an accurate 3 inch rope does not exist, so I made a  winding machine and made my own rope (it did a very nice job for me I might add).  That is why I am now trying to rectify the problem of coloring the rope post-assembly.  Thanks to all who have replied, I appreciate your input.
    March 2010
Posted by Jerome Morris on Monday, February 21, 2011 8:02 PM
An easy fix is to get a can of minwax Golden oak stain. Get the little pint can 'cause you won't need much.
 Get a fine paint brush, natural fibers are best because they hold a bit more stain. touch the paint brush to the line and the stain will just soak right in. repeat as need be. if you want it darker wait a day for it to dry and repeat again
Posted by Don Stauffer on Tuesday, February 22, 2011 8:49 AM
gawga
CGBob,
I should have thought to ask why you want to dye white thread rather than just buy tan stuff.  Model Expo sells a good selection, and it is not real expensive, particularly compared to the price of kits these days.
    November 2010
Posted by Bigb123 on Tuesday, February 22, 2011 5:38 PM
EdGrune,
Red or white onions?  Interesting , to say the least!
Posted by wjbwjb29 on Tuesday, February 22, 2011 5:49 PM
I make all my scale model rope on a ropewalk using white threads of varying diamaters and dye them either hemp or tarred color with rit dye.
Bill
On the Bench:   Trumperter Tsesarevich on deck Glencoe USS Oregon
    May 2006
Posted by Shipwreck on Wednesday, February 23, 2011 7:54 AM
I have a question here. Jerome suggested painting the rope with a stain. It sounds like it works. So, why not just paint the rope on the ship or soak the rope in the bottle before rigging, using the desired color of acrylic paint?
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
