20 mm AA guns in 1/300 scale
    February 2007
Posted by 2/20 Bluemax on Monday, March 28, 2011 1:17 PM
I have finished my Icebreaker , USS Atka. I did not include 20 mm AA guns since the images I found did not indicate they were used(in the mid-50's). I have since discovered they likely were used. Now my dilemma: Where can I get after market 20 mm AA guns in 1/300 scale? If there are none I will have to do some more scratch building. The model measures out to 1/294 scale.
Jim
    August 2005
Posted by EdGrune on Monday, March 28, 2011 2:43 PM
2/20 Bluemax
Jim
No aftermarket in 1:300 scale.    You may want to look at the overscale & too tall 20mm in the 1:350 scale USS The Sullivans Fletcher-class destroyer by Trumpeter.   They're bad for what they're supposed to be,  but the may work out for your application
    March 2007
Posted by bondoman on Tuesday, March 29, 2011 12:02 AM
I'd scratch them. You'd be happy with them, and it's a good exercise. A little stretched sprue, a sliver of beer can metal and a little glue and you will be proud of yourself.
    February 2007
Posted by 2/20 Bluemax on Tuesday, March 29, 2011 4:54 PM
That's what i"ll have to do. I scratchbuilt a pair of twin 40 mm guns. I think they turned out pretty good. I turned the barrels on a homemade lathe using .020" brass rod and used fine fly tying lead wire to simulate the recoil springs. I was just looking for an easy way out.
Jim
