string(cables) on commercial ships
    May 2011
Posted by simbrah on Wednesday, May 11, 2011 5:45 PM
Could someone please tell me how to attach the support cables on commercial ships ?  Thanks Simbrah
    January 2007
Posted by Pavlvs on Wednesday, May 11, 2011 7:37 PM
Can you be a little more specific?
Deus in minutiae est. Fr. Pavlvs
On the Bench: 1:200 Titanic; 1:16 CSA Parrott rifle and Limber
On Deck: 1/200 Arizona.
Recently Completed: 1/72 Gato (as USS Silversides)
    May 2011
Posted by simbrah on Wednesday, May 11, 2011 8:04 PM
I started putting together sea going tug,I will start on a tanker where there are booms it shows that string has to be run to the different booms for supports.I really do not know ow to describe it perfect .
Posted by Don Stauffer on Thursday, May 12, 2011 8:57 AM
There are two main methods people use- gluing ends to booms and yards, and tying via knots.  On smaller scale, many people use monofilament thread, and it is really hard to tie.  So most of those folks do use CA glue to fasten ends, but if you perservere, you can tie knots in the stuff, though with difficulty.
If you use photo etch accessory sets, sometimes there are fittings to terminate the ends of threads that make the job easier.
An alternative that some folks use, though it is not common, is to drill a very small hole through the yard or boom to terminate these threads.  You need a pinvise and a set of #60-80 drill bits and a good magnifier. If you run the thread into a small hole the glue joint is much stronger.  Also, with this method you can tension the thread properly before gluing.  Otherwise you must cut the thread to length perfectly.
These rigging lines are not unique to commercial ships- many warships also have them for various purposes.  In 1:700 scale rigging these lines is difficult enough that some folks omit them, but they really are necessary in 1:350 scale.
Rigging is what seperates the men from the boys :-)
    May 2011
Posted by simbrah on Thursday, May 12, 2011 11:48 AM
Thanks Don for the tip for the rigging strings for ships Tommy Adams
