1/144 Trumpy "Gato" finished
    January 2009
Posted by fermis on Tuesday, May 31, 2011 8:48 PM
.....with "Nautilus Models" PE and resin deck guns. Thus far, things are simple enough, aside from the PE instruction sheet.....very little help and a little cornfusing!
The kit includes a full pressure hull with interior bulkheads, to be all closed up insideTongue Tied. Unless you're doing a cutaway and a ton of interior scratchwork, it's a waiste of time!
 I ended up cutting off all that would not be visible through all the little holes, and to provide access to install bolts through the hull.
 The upper hull is solid, so I cut a pair of holes to feed the bolts through. I also painted the interior area black. The bolts are CAed into place, to hold them till she's mounted on a plaque.
The holes will not be visible, once the deck is in place.
Dryfitting reveales a not so good fit at the step. Will require some filling and a fare amount of sanding.
Posted by Anonymous on Tuesday, May 31, 2011 9:01 PM
Cool...how long is that MOJO?
    January 2009
Posted by fermis on Wednesday, June 1, 2011 6:21 AM
10 inches!
    January 2009
Posted by fermis on Wednesday, June 1, 2011 6:23 AM
Oh wait, you mean the sub?Embarrassed
26+half inches........pretty big!
    November 2008
Posted by Wabashwheels on Wednesday, June 1, 2011 10:39 AM
Abbott & Costello,  Martin & Lewis, Penn & Teller, and now presenting:  Fermis & Manstein !
Posted by Anonymous on Wednesday, June 1, 2011 10:52 AM
Wabashwheels
You mean, "Manstein and Fermis"...
Posted by Jeeves on Thursday, June 2, 2011 9:19 PM
Am just about to start the same kit myself fermis...will be watching this one closely...
    January 2009
Posted by fermis on Sunday, June 12, 2011 11:30 PM
Finally got a bit of bench time!!! Put in over 60 hours at work this past week.......SUCK!!!!!
Anyway, the hull and deck are now one solid piece. Took a lot of grinding and sanding to smooth things out.
The PE set has rails for the tower, but they just didn't look right, and the size was off. I used the kit "uprights" and stretched sprue to simulate the heavy gauge wire rails. I also added the door up front (sheet styrene).
Hopefully, I'll get a rain day or two this week, so I can get more bench time!
Posted by Anonymous on Sunday, June 12, 2011 11:49 PM
Looking goodYes....I think I see some PE on the sail---is that a radar?  Also, are you gonna leave those other doors open on the sail???
    January 2009
Posted by Division 6 on Monday, June 13, 2011 2:34 PM
The side openings into the fairwater are normally open to the sea that's also where some of the air get's to the Main Induction although some boats have the aft end of the fairwater perferated IIRC there is also some storage in there, only museum boats have doors to keep the public out, Balao's have one opening on the front port side where an escape trunk is located, the forward escape trunk (forward torpedo room) is accessed through the hatch on the forward deck of through the rectangular opening in the deck next to the hatch that leads to the side hatch of the trunk.
The door on the front of the fairwater is correct.
If you are interested here is a link to the operating manual for a Fleet Type Submarine, there are also additional System manuals here.
If you care to look at images of any particular boat you may find them at NavSource.
Posted by Anonymous on Monday, June 13, 2011 2:59 PM
Interesting, so the doors should be open?
    January 2009
Posted by Division 6 on Monday, June 13, 2011 3:03 PM
Correct, no doors.
Posted by Anonymous on Monday, June 13, 2011 3:18 PM
Every model I ever see shows 'em modeled closed---I guess Trump got it right when they left off doors in the parts count!
    January 2009
Posted by Division 6 on Monday, June 13, 2011 3:20 PM
A few years ago I think on another forum someone posted pictures of the USS Silversides showing inside the openings.
You could see the aft end of the con tower cylinder and the aft wall was a perforated partition blocking off access to the main induction, there where a few steps down to decking over the main hull.
What's interesting is the con tower cylinders, some boats had convex ends where others had concave, the concave  version kinda seems like a bad idea because of the water pressure.
    March 2004
Posted by Mikeym_us on Tuesday, June 14, 2011 4:05 PM
fermis you do realise that this is the Navy not the Army or the Airforce right?
here are some naval terms
Hatches (Doors)
Bulkheads (Walls)
Scuttlebutt (Watercooler)
Head (Bathroom)
Compartments (Corridors or rooms)
fermis
http://i661.photobucket.com/albums/uu340/fermisb/2011/Gato/001-2.jpg?t=1307938248
http://i661.photobucket.com/albums/uu340/fermisb/2011/Gato/002-2.jpg?t=1307938249
http://i661.photobucket.com/albums/uu340/fermisb/2011/Gato/003-2.jpg?t=1307939125
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    January 2009
Posted by fermis on Friday, June 24, 2011 9:11 PM
Mikeym_us
Hatches (Doors)
Bulkheads (Walls)
Head (Bathroom)
I'm a simple man!Whistling
 Finally got a rain day, with nothing to do but build (mostly).
I made the deck rails with stretched sprue.....took FOREVER!!!
Painted with MM enamels, also took forever. After a few minutes, the compressor would heat up and start squirting water. So, I could only spray for a few minutes at a time. Thanks to my swift, catlike reflexes, the trigger was off before any paint got on top of the water. No blemishes!
The tower is just sitting, not glued yet.
    March 2004
Posted by Mikeym_us on Friday, June 24, 2011 11:58 PM
Never thought you would use a Scuttlebutt as a air compressor. LOL
Get a water trap man it will keep you from treading water. LOL sorry just had to put that joke out there.
fermis
 Mikeym_us:
Hatches (Doors)
Bulkheads (Walls)
Head (Bathroom)
http://i661.photobucket.com/albums/uu340/fermisb/2011/Gato/015.jpg?t=1308967207
http://i661.photobucket.com/albums/uu340/fermisb/2011/Gato/014.jpg?t=1308967194
http://i661.photobucket.com/albums/uu340/fermisb/2011/Gato/013.jpg?t=1308967191
    January 2009
Posted by fermis on Saturday, June 25, 2011 6:13 AM
Mikeym_us
It's got oneTongue Tied. I didn't have any problems till the humidity came up this spring.
    March 2004
Posted by Mikeym_us on Saturday, June 25, 2011 9:18 AM
Get a bigger water trap or try seeing if you can attach a hose to the trap to draw off the water.
fermis
 Mikeym_us:
Posted by Anonymous on Saturday, June 25, 2011 10:20 AM
I thought these MOJO's had deck guns???
    March 2004
Posted by Mikeym_us on Saturday, June 25, 2011 12:15 PM
I think the early fit Gato's didn't have deck guns only the AA guns on the tower. I believe the 2nd fitting saw the deck guns getting installed after problems arose with the Torpedos.
Posted by Anonymous on Sunday, June 26, 2011 9:45 AM
Mikeym_us
Well this one has NONE!
    January 2009
Posted by fermis on Sunday, June 26, 2011 2:54 PM
Manstein's revenge
 Mikeym_us:
I never saw the word "FINISHED" , in my post!Wink
Still trying to figure out which ones I wanna use.
Posted by Anonymous on Sunday, June 26, 2011 2:55 PM
Embarrassed
Posted by Anonymous on Wednesday, June 29, 2011 9:52 AM
fermis
 Mikeym_us:
Hatches (Doors)
Bulkheads (Walls)
Head (Bathroom)
I'm digging the multi-colored scheme...
    January 2009
Posted by Division 6 on Wednesday, June 29, 2011 12:14 PM
In November 1944 the USS Gato had a 4" deck gun forward of the fairwater before that dat it was probably a 3".
Some photos can be found it Navsource.
Posted by Anonymous on Wednesday, June 29, 2011 12:35 PM
No 5 inch?
Posted by CapnMac82 on Wednesday, June 29, 2011 3:14 PM
Seems like it was the class before Gato that had the greatest range of deck guns, with a 3 to 5" bore rifle and a 40mm on either end of the conning tower (it's not a sail until the control room moves into the main hull).
If memory serves, the heaviest-armed US sub was USS Nautilus, which sported a pair of 5" rifles fore and aft of the conning tower.  The CO having experimented with a number of other arrangements, first.Nautilus also executed a bunch of covert insertion missions, too, and was in a number of near-shore actions.
The original design concept for a fleet submarine was as a submersible destroyer, a "stealth" DD if you will, so the deck gun was considered as important as the torpedo tubes, especially so against "soft" targets like unescorted merchant shipping.
    March 2005
Posted by mfsob on Wednesday, June 29, 2011 5:13 PM
You're close, CapnMac82 - Nautilus, Narwal and Argonaut all sported a pair of 6"/53 deck guns.  Quite the wallop for a pigboat, but then, those three handled like pigs too,
Posted by Anonymous on Wednesday, June 29, 2011 9:53 PM
I think this is one of those 5 inchers...
