Lindberg USS Constellation
    March 2004
Posted by Mikeym_us on Saturday, June 4, 2011 6:29 PM
I got the Lindberg kit at a Flea Market today for .50 cents and upon opening it found the hull half started  in a slightly screwed up way with gaps everywhere(builders fault not the kit). Well I got the hull apart and the halves sanded and reassembled and am somewhat satisfied that I corrected the problems. Now I am hoping to get started on the deck with painting before I even insert it in the hull. Now the question being what color are the deck fittings? Would they have been the same color as the Constitution or were they based on the captains preference? As for the deck itself I do believe on a active warship of the late 18th and early 19th century a non-skid coating would have been added as wood gets slippery when wet. So would the Lifecolor Kriegsmarine color of Tier Firnes(Tar Varnish) work?
BTW with the hull in mind what color was the lower hull below the waterline that wasn't covered in copper sheathing or was it all copper?
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
Posted by CapnMac82 on Monday, June 6, 2011 2:21 PM
Constellation presents a number of issues for painting.  Like having any sort of "primary" references like a person might have for a given aircraft.
Which colors at which time (and which ship) gets into some great debate.
Hard to go wrong with a hull color of deep-brown to black--like Testor's Rubber, with metal work picked out in gloss black.  Then a "stripe" along the gunports in either a natural wood color; yellow ochre  or white paint--that's pretty safe.  Fittings in either red or green (I kind of like pale green) are defensible, too.
Decks, though, were "holy-stoned" every day.  Which is that they were washed down and scrubbed with sandstone blocks.  So, the decks were likely a pale silver-gray (like a weathered wood fence) with highlights in amber and grain and joints near-black.  If a person used, oh, "unbleached linen" and let that dry; then washed in, oh, a ghost or gull gray, and let that dry; then a wash of black ought to snap out more detail.
Going into action, the decks were strew with sand for traction, rather than have a coating applied.
Now, masts and spar are going to be another issue.  Naval practice varied as to what was painted, and where the demarcations were.
Hope that helps, some; any.
    March 2004
Posted by Mikeym_us on Monday, June 6, 2011 3:58 PM
Well I don't have "unwashed linen" paint closest I have is Tamiya Buff so it still will be a safe bet to do the washes over that . I actually was planning on doing the hull in black anyways. Right now I am studying the rigging diagaram of the USS Constitution to see what other standing rigging I can add to make it pop out more other than the bare basic rigging in the Lindberg rigging diagram. And I'll probably copy the Constitution painting only deviating from the hull stripe color and trim color same with the masts.
CapnMac82
