Nimitz color question
    August 2004
Posted by uspsjuan on Thursday, June 23, 2011 6:17 PM
Okay guy's and gals, finally got my hobby room back as my middle daughter left for USMC boot camp. time to get back on this project. having issues with the provided color guide.
1. whith of the boot stripe
2. sceam of liberty boats
3.life raft canisters..... all gray?
Thanks in advance....your friendly neighborhood mailman......i didn't smash your box...lol
    January 2003
Posted by TomZ2 on Thursday, June 23, 2011 10:16 PM
Know ye, swab, that this be the Reagan, not the Nimitz, but the colors should match the “sceam of liberty boats”. Arrgh!
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    August 2004
Posted by uspsjuan on Saturday, June 25, 2011 5:14 PM
thanks. that helps with one question
    March 2004
Posted by subfixer on Saturday, June 25, 2011 9:54 PM
That black boat is the liberty boat for only one guy on the ship. That's the Admiral's Barge and it is the only boat painted in that scheme. The rest are gray. The Captain's Gig, which is similiar to the barge, has a gray hull with white upper works.
The boot stripe is about two feet wide or so, and the life raft canisters are gray with a thin black stripe that goes latitudinally (horizontally) around the middle of the canister. It is a rubber seal.
I'm from the government and I'm here to help.
    August 2004
Posted by uspsjuan on Monday, June 27, 2011 6:43 AM
thanks subfixer, i was just about to paint them the wrong color. now i just have to do a little math to get the right demention on the stripe. not sure you could see the black seal at this scale,but i'll give it a test on a couple of them. thanks again
    January 2006
Posted by RedCorvette on Monday, June 27, 2011 7:16 AM
subfixer
I think the boot is a bit wider, about 6' as I recall.
Mark
FSM Charter Subscriber
    November 2010
Posted by Bigb123 on Monday, June 27, 2011 3:43 PM
I forget the exact width I came up with, but here's how I did mine.   First, I measured the dimensions of the paint guide that came with the kit.  I then scaled this up to 1/350.  For example, if the length of the model in 1/350 scale is say, 40 inches, and the lenght of the drawing on the paint guide is 10 inches, then just take all dimensions on the paint guide and multiply by four to get what you need.  So, using this same factor of four, if the width of the boot stripe is say, 1/8 inch on the guide, then it would need to be 1/2 inches wide on the model.  Again, these numbers are made up, but it still works the same.
    August 2004
Posted by uspsjuan on Monday, June 27, 2011 10:09 PM
ok, i guess i'm back to square one on the boot stripe.can anyone brake the tie?
    January 2006
Posted by RedCorvette on Tuesday, June 28, 2011 1:22 AM
uspsjuan
The top of the boot stripe is horizontal and the bottom varies depending on the contour of the hull at that point.   At its widest it is about 7'-8' and it narrows down to as little as 3' vertically at the stern.
Mark
    August 2004
Posted by uspsjuan on Tuesday, June 28, 2011 6:08 PM
makes sence. thanks
