I've got some Model Master paints but none of them seem to be the appropriate hull red color I need. Any ideas out there for a ratio mix using Model Master paints to get a nice hull red for a 1:350 USS Cole.
Cocoa Brown is the suggested color for the hull, but MM paints don't make that color.
My sons been on the Cole for about 2 months and I thought it would be cool to make this model.
Head over to Lowes and their spray paint aisle. The Rustoleum/Painter's Touch red primer is my personal go-to choice for USN hull red.
If you’re trying to match the hull color at the date of the attack, I suspect that you’ll be disappointed.
As you can see, the USN hull red was worn/faded down to a pink gray, and that’s what happened to her bright red hull once again. You can represent your sons’ ship either as she looks to her crew (reality) or to the dry dock crew (a recruiting fiction).
“In history, only some things happen when they should and the rest do not happen at all, but the conscientious historian will rectify these shortcomings.” — Herodotus (484 BC - 425 BC)
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
EdGrune Head over to Lowes and their spray paint aisle. The Rustoleum/Painter's Touch red primer is my personal go-to choice for USN hull red.
Thank your son for me, for his service to our country.
bondoman, that ain't no barge the cole is on but is the semi-submersible heavy lift ship MV Blue Marlin
http://en.wikipedia.org/wiki/MV_Blue_Marlin
I think the Rustoleum Primer sounds like an excellent idea.....Thanks!!
That paint can be a little 'hot' on raw polystyrene. Use some caution and spray 3 or 4 light coats instead of one heavy coat
