Nylon for wire rigging
    March 2011
Posted by Spelunko Bob on Sunday, July 31, 2011 8:16 AM
On my Pamir, scale 1/150 I thought of using nylon thread. But I hear that it stretches. Should I still use it or can I pre-stretch it prior to use? I do not thing standard model riging thread will give the impression of steel cables. Any thoughts appreciated.
Current build: Heller's Pamir. Oooooh Yeeehhh. Stick out tongue
    April 2004
Posted by Jon_a_its on Sunday, July 31, 2011 10:45 AM
unravel 10 denier nylon hose/stockings, stretch & glue in place. a little heat from a heated needle will shrink to tautness....
How you get the stockings is up to you ... Devil
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    March 2011
Posted by Spelunko Bob on Sunday, July 31, 2011 11:47 AM
OK I asked .for that. Naturecaost.com Nylon thread by Shipways I believe. Comments?
Posted by Don Stauffer on Monday, August 1, 2011 8:12 AM
While the nylon thread can stretch, it can also be heat shrunk (very carefully, lest you break something).  There is a big difference between monofilament and regular thread, however.  The monofilament is stiff, almost like fine stainless steel wire, and tying knots in it is a real pain.  However, it looks much finer than it is, which makes it very attractive on smaller scales.
Every time I rig with monofilament I swear it will be the last time.  But the results look so good I end up using it again.
Regular multi-strand thread can certainly depict rigging well. If it is thin enough (say 8 mil) your eye will have a hard time seeing the filaments, though.  A good gray 8 mil is hard to find, though.
Biggest problem I see in finished ship models is using too large a thread, and too high a contrast color.  Black or white does not look realistic- a medium grey is usually a better color, and the lower contrast calls less attention to the rigging.  Rigging should be subtle.  Note that it does not show up in many pictures, depending on the lighting and exposure used.
