tying the shrouds
    March 2011
tying the shrouds
Posted by Spelunko Bob on Monday, August 15, 2011 12:25 AM
Ship Pamir: 1:150
As subject says. When I want to tie them to the turnbuckles, there is no knot used on the real ships. But I can't seem how to replicate this on a model. How would you keep the line together after attaching to turnbuckle?
Current build: Heller's Pamir. Oooooh Yeeehhh. Stick out tongue
    March 2011
Posted by Spelunko Bob on Monday, August 15, 2011 7:41 AM
What I am trying to get at is how to keep the shroud line tight and then seize the shroud. Do you glue the line after threading through turnbuckle? Tie a knot?
    September 2005
Posted by warshipguy on Monday, August 15, 2011 7:59 AM
Bob,
I either turn the end of the shroud back onto itself and tie it into place using another line (seizing) (larger scales), or simply tie a knot (smaller scales).
Bill
    January 2006
Posted by RedCorvette on Monday, August 15, 2011 8:07 AM
I haven't modeled ships with turnbuckles, but when seizing shrouds to deadeyes I use a small alligator clip mounted on a 'third hand' stand to keep the shroud snug while I seize it at the deadeye.
Mark
FSM Charter Subscriber
Posted by Don Stauffer on Monday, August 15, 2011 8:24 AM
A turnbuckle is very small in 1:150. In addition to the knots mentioned, another technique in that scale is to use a toothpick to put two "bumps" of white glue on the shroud and paint the bumps and the thread in between with steel color.
    March 2011
Posted by Spelunko Bob on Monday, August 15, 2011 6:20 PM
These are some good ideas.
At such a small scale, I may get away with glue, but will it hold?
Or, an idea: what about creating 3 knots on the shroud where the sieves would be and paint those white? Would that look realistic or would the knows be to "fat" for their purpose as sieves?
    May 2008
Posted by Billyboy on Tuesday, August 16, 2011 7:42 AM
Could you run the shroud all the way down to the hull and secure it there. If you slide a section of fine tube over the lower part of the shroud before you secure it, that could represent a turnbuckle in this scale? You could add some dummy D-shackles to detail them? It was quite common practice to parcel the turnbuckles, so you could turn that to your favour too. I admit it would not be as effective as seperate fitting, but it's about as simple a solution my mind can come up with.
Will
