The Zvezda Longboat (Wherein I Perform A Fast, Fun Build)
    July 2009
Posted by Vagabond_Astronomer on Wednesday, August 24, 2011 9:13 PM
Let's begin with a simple fact; this is not medieval. In fact, this little vessel is late Renaissance through the early 19th century, perhaps a little later. Nor is it a "lifeboat"; it is a humble longboat. I had purchased two of these a couple of years back for another project, but instead chose to hold onto them.
The back of the box is very deceptive. The model shown here does not do the kit justice, nor is this one built correctly.
The single sprue kit. This model is included with the Zvezda Cog, which would not have had a boat such as this. While listed as 1/72, the design works all the way down to 1/128 comfortably. The hull will measure almost 3" when complete, making it either an 18' (1/72), 24' (1/96), 25' (1/100), 30' (1/120), 31 1/4' (1/125), or 32' (1/128) longboat. It is equipped with a lug sail.
I chose to build mine straight with a couple of slight modifications. The hull was painted a very light gray whilst the inside was done in classic Testor's Flat Brown. Trim was an acrylic brick red and dark blue.
As you can see, this is a fairly small model. The lift block is made from a brown glass bead and brass wire, which were appropriately painted and attached to the mast.
The oars were painted tan. The instructions called for the two backstays to be simply cemented to the inside at the bulwarks. I chose to make two eyebolts from 30 gauge brass wire, drilled two holes and tied the backstays to these and then glued them into place.
Looking aft. Fingers for scale. Ordinary sewing thread was used, with a liberal coating of beeswax.
The furled sail was dry brushed off-white acrylic over wrought iron gray (the same color used for the metal work on the model). The base was made from 1" x 1/8" x 2" basswood.
Whilst a little rough, it was certainly a fast, fun project.
Cheers,
Rob
"I have loved the stars too dearly to be fearful of the night..."
    May 2010
Posted by Tnonk on Wednesday, August 24, 2011 11:48 PM
Looks nice Rob, Great job.
I know what you mean about just doing a fast, fun build, my Bounty started off as one.  It's still fun but the fast part just didn't happen for me.
Adrian
    March 2010
Posted by shoot&scoot on Thursday, August 25, 2011 1:07 AM
Sometimes it's great just to do a "slammer" for a change.  She came out quite nicely.  Reminds me of the vessels you see in 18th century paintings showing Europe's inland lakes and rivers.  Thanks for sharing.
        Pat.
    May 2008
Posted by Billyboy on Thursday, August 25, 2011 3:29 AM
Nice results!
This is a versatile little kit. Over here in the UK a lot of railway modellers use it for small fishing craft- there have been a lot of magazine articles about it. The beauty of the kit is you can buy five and make every one slightly different (adding half-decks, clinker planking from microstrip, cutter rig, etc etc.)
Another range of models of small boats, albeit wooden, can be found here- I have had a go and they are surprisingly good fun. http://www.gk-modellbau.de/
Will
    July 2009
Posted by Vagabond_Astronomer on Thursday, August 25, 2011 7:05 AM
Thanks for the compliments!
I was planning on making the other kit into a anchor hoy in 1/200 - 1/220 range, but instead am now leaning towards a cutter rigged version (both inspired by Dan Thompson's work; I read about his anchor hoy in the early 1990's in "Model Ship Builder" magazine, a much missed and lamented publication). And when I build it, yes, it'll be shown here.
Cheers,
Rob
    May 2008
Posted by Billyboy on Thursday, August 25, 2011 7:38 AM
Is that anchor hoy this one? http://picasaweb.google.com/116637781725296267499/AnchorHoy#
These are really cool conversions. His HMS Gorgon is absolutely sensational. If only I had the patience and skill (and plastic-stock supplies) to do that to a Heller kit.
Will
    September 2005
Posted by Sprue-ce Goose on Thursday, August 25, 2011 7:47 AM
I recall seeing the kit at a LHS but didn't buy due to not knowing what the kit looked like inside the box.
Thanks for the photos.
Really nice job of building the kit !  Cool
I'm quite impressed by that little model.
If I happen to see the kit again I will certainly buy it.
    March 2006
Posted by TD4438 on Thursday, August 25, 2011 4:08 PM
For a simple little kit,it sure looks good.
    July 2009
Posted by Vagabond_Astronomer on Thursday, August 25, 2011 7:45 PM
Billyboy
Will
It certainly is. At the time I found out about this (originally), I was building a wooden one in my preferred scale at the time, 1/384 (1/32" = 1') based upon the Grimwood drawings. I saw this one and felt wholly inadequate. Stumbled upon his Picassa albums a few weeks back. Make no mistake, the man is talented.
    July 2009
Posted by Vagabond_Astronomer on Thursday, August 25, 2011 7:51 PM
Tnonk
Adrian
Adrian, my friend, your Bounty is one of the reasons I did this! There is going to be a bit of a hold on the Constitution project, and wanted to keep busy. Your project was inspiring!
    March 2005
Posted by mfsob on Saturday, August 27, 2011 7:10 AM
Looking at what other's do is what inspires all of us to do better. That, and looking at our own past efforts. I really like what you did with this litte kit.
    July 2009
Posted by Vagabond_Astronomer on Saturday, August 27, 2011 9:43 PM
One of my favorite sites online is the National Maritime Museum, Greenwich. They have an online collections catalog that is simply brimming with potential. Simply searching "longboat" or "armed launch" or even "hoy" brings up dozens of possibilities.
The Zvezda kit could be the starting point for many of these. So far, I've found several possible vessels for the other kit. The first Dan Thompson tackled as well; a cutter rigged longboat -
Dan Thompson's Model
NMM Model
Another is a 23ft armed launch. This would make the model 1/96 -
23ft Launch for HMS Texel (1799)
Finally, there is a humble 36ft cargo hoy -
Hoy (1730)
I will admit, I lean heavily towards the latter, based upon that rig.
Meanwhile, other projects await.
Cheers,
Rob
    May 2008
Posted by Billyboy on Sunday, August 28, 2011 4:01 PM
That hoy is a super little craft. The blind gallery is a particularly nice little touch.
    May 2010
Posted by Tnonk on Wednesday, August 31, 2011 11:16 PM
Thanks for the comment Rob.  I guess turnabout is fair play - i was inspired by your Bounty which prompted me to try a fun build.
I get wrapped up in a larger scale project & of course it tends to drag on forever.  I don't have a lot of modeling time, so the larger scale projects take up all of my time when I can get to them.
I also have 3 stalled aircraft builds that I can't seem to get back to, along with my Jolly Roger thats stalled .
Ya know, sometimes ya just gotta build a quick little model to bring you back to your roots. Have fun, enjoy yourself without stressing out, and get back to building.
Anywho, that little anchor hoy is fantastic, along with the others.
Truly inspiring work.
Adrian
