Simulating salt spray and/or deposits on ships
    December 2010
Posted by Old Puma on Tuesday, August 30, 2011 8:13 AM
Well, I've tried asking this question of my aircraft (specifically seaplane) hobbiests with no luck. Now, I'll try my "shipmates". How can I simulate salt spray and/or salt desposits on seaplane pontoons and fuselage sides near the water line? I would assume this should be done as a final step in finishing a seaplane. How about using Spelnda, or other artificial sugar, deposited/sprinkled on "Testor's Model Master Flat Clear Lacquer Finish", which you apply with a very fine brush?  HELP!!
    February 2006
Posted by GeorgeW on Tuesday, August 30, 2011 9:56 AM
To simulate salt stains on the woodwork of period ships, I use simple white chalk rubbed on after the final painting. The beauty is you can keep going over it until you get the effect you like.
    March 2005
Posted by mfsob on Tuesday, August 30, 2011 11:21 AM
Kind of depends on the scale we're talking about. In 1/72 it would have to be very subtle or it'd look overdone and cartoonish. I tried to get something along those lines with my just-completed A6M2-N Rufe, using Polyscale's acrylic Dust, and got a very faint, but noticeable - in the right light - whitish line along the floats.
Another thing you have to consider is what kind of seaplanes are we talking about? Some big ones, like PBYs, for instance, were moored in the water at forward bases but pulled out on land at large bases, like Pearl Harbor; smaller seaplanes like Kingfishers were usually hauled back aboard their ship or up onto land when their patrol was done. In all those cases, the pontoons and hull areas that contacted salt water would be hosed off with fresh water as soon as possible. I am not a seaplane expert, but I believe, in general, that all the naval air forces preferred to keep their seaplanes out of the water as much as possible, for the simple fact that seawater is murderously corrosive.
    March 2006
Posted by TD4438 on Tuesday, August 30, 2011 7:00 PM
I plan on attempting this with the 'snow' in Tamiya's weathering kit.It goes on extremely thin.
