Academy Warspite
    December 2006
Academy Warspite
Posted by Jester75 on Sunday, September 25, 2011 9:24 PM
Anyone looking to get in on this one?
Warspite
Looks to be a realy cool ship. I was browsing ModelWarships earlier and found this astounding upgrade set being produced by a company called Pontos. Some of the pe looks phenomenal!!
Pontos upgrade set
May have to hit Mrs. Claus up to put this one under the tree.
Eric
    January 2010
Posted by Bruno Schielzeth on Monday, September 26, 2011 8:01 AM
I have the review kit on the bench this very moment. If you like classy old ships then save up for this one. It's a good kit. Not perfect but darned good. Molded in 1944 "ground pounder" bombardment fit but it can be back-dated to 1942-43 by leaving some parts off and filling a few holes. The photo etched detail set is going to be necessary. No etch in the kit except for the heavy cranes. Detail level is good. Not stunning with 1200 parts, but darned good. If you want a Warspite then you won't be disappointed in the Academy offering. A fun build with lots of good detail where it counts.
    August 2005
Posted by Tracy White on Monday, September 26, 2011 4:46 PM
Two reviews Online:
ModelWarships
InternetModeler
Tracy White Researcher@Large
    December 2006
Posted by Jester75 on Monday, September 26, 2011 5:00 PM
Thanks for the links Tracy. Looks to be a pretty decent kit and that upgrade set should turn it into a work of art. Asahme about the molded angle of the main guns but that shouldn.t be too hard to fix.
Eric
    July 2004
Posted by stikpusher on Monday, September 26, 2011 11:12 PM
I will likely pick one up to add to my stash and build one day. I like her battle record better than any of the other 1/350 WWII Royal Navy Battleships and Battle Cruisers available.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2009
Posted by Felix C. on Tuesday, September 27, 2011 12:18 PM
What needs to be done for 1942/43?
    August 2005
Posted by Tracy White on Tuesday, September 27, 2011 12:37 PM
Less anti-aircraft mainly. I don't have exact locations, this is just what a cursory examination revealed.
    January 2010
Posted by Bruno Schielzeth on Tuesday, September 27, 2011 12:38 PM
The repairs after the Fritz X hits in late '43 included removing the Walrus planes and adding a half dozen 2 pounders around the catapult, adding two more 2 pounders on the bridge deck, adding another AA control radar to the aft deck house, and I'm sure a bunch of other things. Academy gives you two bulkheads, E-49, to replace the gun tub/bulkheads for the '44 fit on the bridge. The holes around the catapult are easy enough to fill with .035-.040 rod and paint to blend in. The single AA control is shown but not explained in the instructions. Basically fill the two holes in the riser and just glue down one unit instead of two.
I'm sure someone, Tracy perhaps, has a long and complete list of things needed to backdate the Warspite, but it sure seems like it can be done pretty easily.
There are other corrections needed to the kit, mostly minor stuff, but still wrong. I can't spell them out here at the moment however.
I'd love to see a pre-1937 version from someone. There's no way to do that from the Academy kit but maybe someone else will issue it? We can hope.
    September 2005
Posted by warshipguy on Tuesday, September 27, 2011 2:11 PM
I would like to modify the kit to her 1939-1940 appearance, as she appeared when destroying the German destroyer fleet in Norway.  I like the clean look.
Bill
Posted by tigerman on Tuesday, September 27, 2011 3:04 PM
Too bad it's not the WW I version.
That being said, it looks like a very nice kit. Price appears to be reasonable too.
 Eric
    October 2003
Posted by woodrow76 on Wednesday, September 28, 2011 9:47 PM
Hey,
I believe Trumpeter's 1/350 Queen Elizabeth is going to be an earlier fit, possibly 1918 like it's 1/700 release and I also saw on a few different forums that Academy may add more Warspites/Queens of different fits.  Although I build armor, I'll definitely will buy it.  Now only if some one will make a 1/350 plastic Rodney/Nelson and my favorite Agincourt...
    January 2010
Posted by Bruno Schielzeth on Thursday, September 29, 2011 9:29 AM
I'd love to see an early QE class and hopefully someone will provide it? The ships are vastly different. I actually prefer the older twin stack look. Much sleeker and just as nasty. If it comes to pass I'll be building that one too. It would be great to have the early and late models side by side in the display case. By WWII all five barely looked like the same class anymore. However they sure were effective. Smile
