I am still fighting with my 1/200 Arizona. I finished grinding and polishing the propellers from G-Factor and have attached the main deck section to the lower hull. Last week I ordered the White Ensign anchor deck plate detail for the model with the intent of just adding a little visual interest for only a few dollars. As with many things, it sounded great at the time, not so great in practice.
When I received the piece it looked great, well packaged and ready to go. Excitedly over the weekend I cut the brass from the sprue, carefully filed the edges down and placed the piece on the foredeck. Much to my dismay it did not fit. Aligning the edge on one side made it slide out of place on the other. Aligning the middle meant that neither the left or right sides aligned. The profiles for the curves near the capstans were wrong. I mean the thing just plain does not fit.
So once again I ask the questions to those of you who are more experienced than me with ships (which is about everyone), is this a common problem with the WEM parts? With Photo-etch in general? I would assume that the company manufacturing the brass details would have modeled them off of the actual model, is this not the case?
In any event I think that the WEM bit just sealed the coffin shut on me buying any more aftermarket items for this model. OOB is the way I am proceeding from here on out.
Thanks all
Adam
