Kit: ICM 350 Scale Konig
Additional Materials: WEM &
Verlinden PE; BMK brass barrels; Builder's anchor chain; top masts
and yards scratch built with brass
Paints: Tamiya, Vallejo, Gunze, Revell
Germany
After two plus months I've decided that
my rendition of ICM's 350 scale Konig is finis. This has been the
largest and most complex model I've built and my second serious ship.
It took me over two months to finish and I'm out of gas. I did learn
a bit though.
No wish to knock other modeling genres
but for me ships are the most challenging. There are times when my
eye knows what it wants but the hand betrays it. There are many times
that I don't know what I'm doing. Hopefully both these conditions
will improve with experience but I know that I don't have the “eye”
or the patience to be a good ship modeler. I'll settle for competent.
Because of the modular nature of ship
building, I found that I did not always anticipate a problem before
it happened and instead spent a lot of time fixing things afterward.
I don't want to blame the coach, but maybe I did not chose the best
large scale kit to tackle. As I understand it, Konig was ICM's first
large scale offering went it came out in 2000. Panel lines were
raised which, at least in airplane world, is the sign of a crude kit.
Flash was all over and fit was uniformly poor. The part count of 500
wasn't bad – but nearly everything required attention which cost me
a lot of time. I used a lot of Apoxie Sculpt (a product I much prefer
to putty) far more often than I'd like. There was no question about
the necessity of building brass masts as the plastic was soft and
weak. That said driver error was always a factor.
I used the information from the
“Imperial German Navy in World War I”, especially the article by
Mr. Tanner for painting. I also used Gary Staff's “German
Battleships 1914-1918 (2). When the two conflicted I used Tanner's
data. Originally I followed some charts and used Tamiya XF-66 Light
Grey for RAL 7000 and XF-20 Medium Grey for RAL 7001. The charts did
agree that the only paints that fit the bill perfectly outside of WEM
enamels were German Revell's Grey (RAL 7000) and Silk Grey (RAL
7001.) This brand is not available in the US but I wasn't happy with
XF-20 so I bought some German Revell colors on eBay. Revell's RAL
7000 was a little lighter than the Tamiya but it wasn't worth
repainting the entire hull. I did, however, repaint the
superstructure with Revell RAL 7001 and that was worth the time.
Excellent paints BTW – I think they hand brush as well as Vallejo -
and I've since bought several.
I wanted to build my Konig as it
appeared on the way back from very spirited operations in the Baltic
in September – early October 1917. (Jutland was out. It was obvious
from the start that project fatigue would be a factor and looking at
WEM's torpedo net arrangement needed for Jutland had me running for
cover. A wise move in retrospect. After Jutland the German Navy discarded torpedo nets.) After looking at scores of photos I
decided to give Konig some serious weathering. I kept thinking of all
of that coal (not to mention main guns which were used heavily in the
Baltic) and the North Atlantic/Baltic. (Check the photo below of
Konig class Kronprinz below.) I used Mr. Griffith's filter technique but added
some streaking from armor land as well as some fading with pastels. I
rather liked the deck which was done in four shades and enhanced with
a Verithin black pencil which did wonders to the panel lines. I take
full responsibility for the paint job – in this case it came out
the way I wanted. No question that weathering would go better with a
dio, but we'll take one step at a time.
PE is simply a mystery to duffers like
yours truly. I found some of the embellishments almost comic – you
could put on a PE seat inside the 88 guns mounted on deck. We're
talking items the size of an infant gnat. The cranes and funnel
covers were very worthwhile, although I think I could have
scratch-built both. WEM railings and ladders are beautifully made but
extremely easy to mangle at any step along the way. I had real
trouble when putting a thumb down in the wrong place and smushing a
good chunk of rail. I fixed what I could and even replaced a little.
Due to a misunderstanding on WEM's rather vague instructions I ended up short some two railings. The only thing I
had was some Verlinden generic 2 railings that I bought on sale. I'm
sure WEM's products are superior, but the Verlinden stuff was thicker
in every dimension, a snap to put on (you could bend the stuff with a
pliers during construction – wouldn't want to try that with WEM
ultra-fine) and nearly impervious to a misplaced thumb. And from
three feet away, it's just as good. One bit of good news though. At the recommendation of someone on Phil Foley's site I got some Aleene's Tacky
Glue to help set the railings. There is now a Super Tacky Allene's available
at any craft store. The tack on this stuff is incredible. It was
perfect for PE: if you could get just a dab of that stuff on, your
railing would stay up. While it was up, I used some thinned Gator
glue to slip along the length of the railings – occasionally used
some CA – and the railing was on. Aleene's cures in several hours
but begins to set quickly, so as soon as things were holding, I tried
to remove as much as possible with a tooth pick. This stuff will help
out in many a jam. Good as gold.
Rigging is likewise a mystery. Although
I've found ship Meister Jim Baumann's sprue making methods a great aid in several
kits, I just don't get how you can get the sprue to get sticky enough
to grab using plastic cement. I found it either simply didn't
work, or the plastic cement would melt it off the brass. (I think
this would work nicely if you were gluing sprue to plastic, but brass
has me stumped.) I did use some sprue in the aft. But if I had
something to anchor the line to I had much better luck with
Danville's 6/0 (70 denier) black waxed nylon fly tying thread. It's a lot thinner than 2lb mono
filament but it's made to tie. Do a simple half-itch, draw the line taught and apply a
mini-dab of thin CA. Nylon line does shrink under heat (as does mono)
but it was straight enough that I didn't take any chances. Things
didn't exactly work well, and a close exam would be worth a chuckle
or three. But the rigging done at the end of the model was better
than that done at the start. I'll take that as a good sign. And it
looks okay from five feet.
Pics below.
Eric
