Cyber-Hobby just made a post in HS's Ship Chat that they have it for 1599 Yen, about $205 US. Shipping? I don't know. That's basically half price. And a good deal I believe. Shipping will be expensive. The box is 31" long, 6" deep, and 11.5" wide and weighs in about six pounds. It's well packed but it won't stand up to normal UPS, FedEx, or USPS handlers. They could break a steel brick!
As for the kit: Stunning won't even come close to describing it. 100 assembly steps in the manual. Yes MANUAL! Not instructions. The detail level is beyond anything I've seen before. The multi-part lower hull WILL require some minor filler, the fit isn't 100% perfect. That has been the only filler needed and I'm up to the main deck. So far the fit has been perfect. Upper and lower hull, and MID HULL, all fit great. The waterline plate becomes the mid-deck for the full hull build. This hull will NOT twist or bend.
I haven't counted the parts yet, and I have to for the review, but I figure about 400 in photo etch, not all used, 100 polycaps, 50 screws, nuts, bolts, and probably 2500 parts in plastic, not all of them used. Two sheets of decals for linoleum and the various shutter assemblies on the gun control turrets. Plus vents and other low relief details.
The molds will be used for an early/mid war Yamato and the Musashi as there are dozens of dimples marked on the bottom of the decks and inside the hull with Y and M and not all the Y holes get opened.
All the guns, gun control turrets, major spot lights, cranes, and catapults can be moved or removed after assembly due to the polycaps.
The three main turrets have interior details and the traverse gears are there with a partly detailed full barbet.
So far everything fits perfectly as long as you erase any hint of sprue gates or nubs on the photo etch. There is no room for error in this kit.
The detail level looks very good to me but might be overdone for some. Even the triple 25 mm guns have visible breaches and ammo bins and muzzle flare. No more "lumps with bumps". All the larger guns can be elevated as long as you leave off the blast bags.
My review kit included two of the three Detail-Up sets. The turned aluminum 18.1" barrels plus a dozen or so shells, and the railing set. I have permission to ignore either/both sets as they are optional. However the barrels will be used. Basically Plug & Play. The railings? I won't have the time to drill 400 .3 mm holes, glue in the 400 photo etched stanchions, and then string in the .1 mm copper wire. So far the railings are the only thing the basic kit is missing. The kit includes all the necessary photo etched ladders, inclined ladders, decking, platforms, antennas, and radars. Plus a ton of detail parts like search light covers and other bits I haven't checked on.
This kit is light years better engineered, designed, and molded than the originals. There isn't a single part that isn't new tool.
The only after market you might want is the degaussing cables, the railings, and the guns. The kit will look great without them but they would only make it even better. If you have the time to use them. I won't, sadly.
The catapults are in plastic but seem pretty detailed and delicate. Photo etched ones would be better, I'm sure, but the kit ones look fine to me.
The kit includes a Yamato reference book in Japanese and English, a full sized color profile, and a small correction sheet. At the moment Amazon and others have used "A Glorious Way to Die" and other Yamato reference books for a very fair price. I ordered a couple different ones for less than $20 including shipping.
So the big question. Is the Yamato worth the premium price? Well, only the buyer can decide that. For the MSRP of $417 I'd hesitate but it is discounted in a number of places. For $200-$300 it is a lot of model for the money. The detail sets won't cost all that much in comparison.
A good model builder will get about three months or more of fun model building time with the kit. It's not as fiddly as the Dragon Scharnhorst but the wow factor is going to be much higher I think.
I'll be happy to answer any questions on the kit as long as it doesn't keep me away from the bench too long. I have to turn this monster in on February 1st and I can see 10 hour sessions at the bench in my future. Heck, I watched the Packer's game with a TV tray full of parts in front of me. I air brushed parts during the commercial breaks and half time. Oh, speaking of air brushing: buy LOTS of paint for this ship! I custom mixed a full ounce of Kure Gray for the build. I'm going to have to mix up another one at least. There are acres and acres of plastic in this thing!
