Dry Transfers
    March 2005
Dry Transfers
Posted by gpal on Saturday, December 31, 2011 7:25 AM
I have some dry transfer numbers to put on the hull of the ship I am working on and would like to know how you guys apply dry transfers and in what order with the dull coats which is going to be Tamiya flat base X-21 and Future. Do I need to apply a dull coat where the dry transfers go before applying? Do I need to apply a dull coat over the dry transfers like you do with water decals?
Thanks in advance, George
Posted by Don Stauffer on Saturday, December 31, 2011 10:03 AM
Do NOT dullcoat.  While the dry transfer lettering doesn't silver like decals, they still go on better over a somewhat glossy finish.  But they will go over matt finish.  DT letters are not as finicky as decals.
Whether you want to dullcoat them or not is a personal preference.  They appear somewhat semi-matt normally.  A clearcoat of either sheen does protect them, but is not absolutely necessary.
    August 2006
Posted by HawkeyeHobbies on Saturday, December 31, 2011 10:19 AM
Dry Transfers are waxy, which is what makes them stick. Make sure they are warm before applying. They burnish better on flat sheen surfaces, it gives the waxy material something to grab on to and hold. CAUTION! Some clear coats will cause them the breakdown and run especially if applied with a brush. Airbrush any clearcoat lightly, multiple layers if necessary.
Make sure the surface they are being applied to is oil free. As I said warm Dry Transfers stick better, body temperature is sufficient. I will set mine on top of the fluorescent lamp above my bench which has a radiant temp of just over 100F. Thirty seconds or so softens up the Dry Transfer, making the back sticky and ready to be burnished on the model.
I like Dry Transfers because they are easier in most cases than decals to apply. They weather more realistically too. They are also great for masking too, but that is for another post.
Gerald "Hawkeye" Voigt
