USS Intrepid CV-11: 1/400 paper model
    February 2010
Posted by paulhelfrich on Wednesday, January 25, 2012 11:34 PM
This is the JSC 1/400 paper kit of the USS Intrepid, CV-11.  I added photoetched railings and crew figures from Tom’s Modelworks to the basic kit, as well as masts made from styrene and brass rod and stretched sprue rigging.
Here’s the build by the numbers: 64 wire gun barrels for the 16 40 mm quads.  53 20 mm gun mounts.  40 crew figures.  33 paper aircraft (Corsairs, Hellcats, Avengers, and Helldivers), each one a miniature paper kit in itself.
And about 2 years to build it, although I worked on many other projects simultaneously.   The planes don't have an option to build them with wings folded; I'm sure it could be done, but I'm not quite the scratchbuilder to pull that off.  Building them with wings extended was plenty hard enough for me!
The kit is printed depicting the Intrepid in her 1945 MS22 camouflage.  JSC’s “Navy Blue” on the lower hull is a bit bright; in the future, I may choose to darken the printing with markers on similar kits.  On the other hand, their take on “Deck Blue” is pretty good.
The JSC 1/400 kits are all waterline, so I mounted the ship on a water base just as I would with any other waterline kit.
    March 2007
Posted by bondoman on Thursday, January 26, 2012 12:12 AM
Bow DownI've tried a few card models and that's HARD.
Really wonderful, true modeling.
    May 2009
Posted by Pawel on Thursday, January 26, 2012 3:59 AM
Hello!
A very nice ship! Paper model flourished in Poland since 1957, when "Maly Modelarz" - a periodic that gave you one paper model a month started coming out. Paper models gave you the opportunity to build something nice, when the plastic model kits were impossible to get. Some four years ago I finished USS Belleau Wood from "Maly Modelarz". It paid off to put a very thin, almost transparent coat of paint to the model by airbrush, to adjust the colours of the camouflage, and then to paint all the edges of parts, where paper colour shows. If you wanted more paper models from Poland, maybe I could help you. Any plans for future builds? Good luck and have a nice day
Paweł
www.vietnam.net.pl
Posted by Tojo72 on Thursday, January 26, 2012 10:25 AM
that is really cool YesYesYes
Posted by Gamera on Thursday, January 26, 2012 10:35 AM
Wow, that's amazing! I've built a few simple paper models but that's gee whiz wow!
 IndifferentWow
    March 2006
Posted by TD4438 on Thursday, January 26, 2012 10:38 AM
Very cool to say the least.Do you have any WIP pics?
    March 2005
Posted by mfsob on Thursday, January 26, 2012 2:26 PM
You paper model guys ... wow ... Yes
    February 2010
Posted by paulhelfrich on Thursday, January 26, 2012 2:49 PM
Hi Pawel - yes, I've built a few Maly Modelarz kits of 1980s vintage, including the October Revolution battleship and the Minsk aircraft carrier.  Really tough builds due to the older paper used in the kits.  I have some new Maly kits though, including the battleship Hiei and the Belleau Wood that you mentioned, and they are MUCH improved - they look to be really nice, and much more detailed than the older kits.
I'm currently building a 1970s paper kit of the USS Oklahoma by H.G. Watkins.  After that, I'm going to tackle the FlyModel USS Alaska, which in 1/200 scale will be almost 4' long and and will probably take me the rest of my life!
I do regularly buy paper models and accessories (like railings and gun barrels) from a source in Poland via e-bay.  Thanks very much for looking at my model!  Big Smile
    August 2008
Posted by tankerbuilder on Thursday, January 26, 2012 6:20 PM
Hi PAUL ! Hey , do you remember PMI from BEAVERTON ,OREGON ? I used to get my models from them ,but , they are gone and I can,t find anyone this side of the ATLANTIC that sells them . Do you know of someone ? I am at present doing the KROPRINZE in 1/200 in paper and before I build a part , I  take the paper parts and use them as patterns .YUP , I am doing a KRONPRINZE in plastic right alongside the paper one ! I am now at the point where I will be putting the decks on the paper one and at a final sanding on the plastic hull .I have duplicated the plating lays just as they would be on the real ship .That,s the ONLY thing you don,t get in the paper ones . I also have a cruise ship in 1/200 . I will get to it eventually  . Right now I have the WILHELMSHAVEN model of the CONTI-BELGICA container-ship under construction .What I like about the paper models is the sheer variety of subjacts available . I just wish they all did them in 1/250 or 1/350 instead of being all over the place . The sheer fun factor at how much my own skills have improved in plastic after building these is absolutely amazing ! . i have learned to do in plastic what I HAVE to do in paper because it has made me a all around BETTER modelbuilder . I even use paper ship technology in plastic to do 1/160 and 1/87 scale ships for clients .All they say is either Holy Cow ! or Jumping jehosephat ! How did you do that ! that is almost as good as the fees they pay ! I need more paper ones though .Can you put me on to some firm here in the states ? If not does your supplier in POLAND have a catalogue ? That is one beautiful carrier  , and yes those little planes are a challenge aren,t they ?.OH , by the way , I spray ALL my models with a flexible clearcoat so I can adjust the paint if I have to .       tankerbuilder
    February 2010
Posted by paulhelfrich on Thursday, January 26, 2012 10:51 PM
Hi Tankerbuilder - I recommend this seller: http://www.ebay.com/sch/debica/m.html?hash=item35b8d0792c&item=230733936940&pt=LH_DefaultDomain_0&_trksid=p4340.l2562
"Debica" on e-bay.  You can also order direct from GPM in Poland: http://www.gpm.pl/eng/index.php?akcja=kategorie&poziom=2&kat=274   but their shipping charges to the US are pretty brutal.
I, too, used to order from PMI a lot.  Sad that they're gone.  I have that Modelik Kronprinz kit, by the way!
Thanks for checking out my model!
    September 2006
Posted by raider-hall on Monday, January 30, 2012 11:05 AM
very well done. i build mine from scratch.Yes
    August 2011
Posted by BashMonkey on Sunday, February 19, 2012 9:51 PM
Cool. I have 2 paper sailing ship kits on their way from Poland right now. Love the carrier, been very tempted to pick up a battleship or two.
 ALL OF YOUR BASE ARE BELONG TO US!
    June 2010
Posted by DoogsATX on Sunday, February 19, 2012 10:26 PM
mfsob
Ditto
And I thought this one I saw yesterday was daunting:
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
Posted by tigerman on Sunday, February 19, 2012 10:58 PM
Nice models guys.
 Eric
    August 2008
Posted by tankerbuilder on Saturday, March 10, 2012 7:07 AM
HEY,DOOGS! How,s it going? Those papermodels at the show were awesome werent they?Thebuilder has them and more.He likes to do the planes that have clear canopies and cockpits.Paper planes are a challenge though.  TANKERbuilder
    September 2005
Posted by warshipguy on Saturday, March 10, 2012 10:22 AM
My hat's off to paper modellers!  I'm working on the HMS Cleopatra frigate by Model Shipyard by using the paper parts as patterns for plastic.  It is one of the most difficult models I have ever attempted!  I also have the JSC HMS Dreadnought kit but am missing the first few pages of the instructions due to a printing error (I bought the kit on eBay).  I, for one, would like to see more building logs to get a better idea of how to properly proceed with one of these kits.
Bill
    May 2009
Posted by Pawel on Saturday, March 10, 2012 4:51 PM
Bill - funny thing, both Shipyardand JSC are Polish companies, somehow we came to be the leaders of the paper model industry :-))). As for the Shipyard offerings, their models always looked mighty complicated to me, if I was to build one, I'd probably scale it up (like from 1:100 to 1:50) and build one in wood. But I've seen them finished on a model fair here in Poznań, and they sure look impressive. Sorry to hear about your problems with the instructions for the other kit. I checked if I could help you and I located scans of the entire model online, they can be downloaded here. Should you have problems with this one, PM me and I'll mail you the files. I think I could also help you with questions about paper models, and I can also translate from Polish if necessary. Good luck with your projects, have a nice day
Paweł
www.vietnam.net.pl
    September 2005
Posted by warshipguy on Saturday, March 10, 2012 6:19 PM
Pawel,
Thank you! I appreciate your offer and will be in touch with you!
Bill
