DON,you and MIKEYM US need to be advised she,s full of surprises.I am at the point of mounting the stand so I can continue the build.The holes they drilled are , (on my example at least) cockeyed as all getout. The Brass stuff is easy to figure out IF you read that book carefully at least three times. Now on that stand.Go to HOBBY LOBBY and or your LHS and pick a better piece of wood.
All the removal instructions must be followed faithfully.Do NOT and I do repeat,DO NOT try to sand down the plate detail on the hull,and don,t do a halfway job either.If you sand all the way you will wind up with a paper thin hull and with the warps it may have, is NOT want you need to deal with.REMEMBER this is the OLD REVELL mold. I think it may be near your,s and mine ages DON:
I do believe it will build up into a fine looking model though.And like you DON There,s something about the paint pattern of the "GREAT WHITE FLEET"!Catchya Later-----TANKERbuilder
