Trumpeter USS Gato 1941, 1/350. Silicon water base WIP
    July 2005
Posted by Lloyd on Sunday, April 8, 2012 9:52 AM
Hi, my first attempt at this, not sure if it will work but anyway. I cut the base to create a rough seas effect, sanded them down a bit and glued the two halves together. More updates to come.
    February 2004
Posted by martinjquinn on Wednesday, April 18, 2012 12:37 PM
I have this kit in the stash...will definitely try and follow along.
Martin
    July 2005
Posted by Lloyd on Wednesday, April 18, 2012 11:56 PM
I've made this test piece, very crude but looks promising. I used royal blue and blackish blue as undercoats. The dark blue looks good with the silicon tinted with tamiya clear blue and a few drops of black paint. It has quite a nice translucent watery look to it which is what I was after, rather than painting celluclay or whatever. I added some curved clear plastic to create the bow wave.
I've discovered that silicon melts foam, so I'll do another test with the foam sealed under more undercoats.
upload pictures
adult upload image
image upload
adult upload image
    March 2007
Posted by bondoman on Thursday, April 19, 2012 12:57 AM
My only piece of advice, and FWIW. Find a picture from above of a Gato underway. Wakes are not to be guessed at, so find a good image and copy it.
    July 2005
Posted by Lloyd on Thursday, April 19, 2012 1:24 AM
Thanks, I have lots of shots, but thats a good one. Going for rough seas, just to make it interesting.
image upload
    March 2007
Posted by bondoman on Thursday, April 19, 2012 1:48 AM
I think your model is 1/144, correct?
Which boat are you planning to build?
I've always wanted to build a ship model with pitch and roll.
The painting has her bobbing like a cork.
    July 2005
Posted by Lloyd on Thursday, April 19, 2012 2:15 AM
It's 1/350, probably too big for a first try at water effects. Having the ship listing and a froamy spray effect from the side could look cool.
    March 2004
Posted by Mikeym_us on Friday, April 20, 2012 11:16 PM
Try a scene that was typical of most US subs during the war. Pulling a downed aviator out of his raft and onto the deck shouldn't be too hard to make a 1/350 scale raft and using PE figures from a 1/350 scale set.
Lloyd
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    July 2005
Posted by Lloyd on Saturday, April 21, 2012 8:56 PM
I like that idea, I've seen some scale rafts with PE oars, very detailed. I could have a bunch of them adrift. Once I sort out the water problems, cheers.
    July 2005
Posted by Lloyd on Saturday, April 28, 2012 11:23 AM
After some so-so results I dropped the silicon idea and decided to create the water by hand sculpting the surface. I had problems with thousands of airbubbles, but I can see it working if it's just laid staight onto a blue painted surface. It's tricky to work with anyway.
free image hosting
 I'll get around to that later, but the material I found is an oil based sealant putty, really fantastic stuff and I can see other uses for creating gound work. Takes ages to dry though. This is purchased in Australia, I'm not sure what the equivalent is elsewhere.
gif hosting
    July 2005
Posted by Lloyd on Saturday, April 28, 2012 11:26 AM
The model is primed...
jpg upload
Deck underpainted. No underpainting for the hull, I'm using black spray paint so there's no point.
upload images
image hosting
image hosting
free picture hosting
Engine grey for the deck.
image hosting adult
picture hosting
    September 2007
Posted by SuppressionFire on Saturday, April 28, 2012 11:32 AM
Interesting project Lloyd!
Will be following to see how the water turns out.
The main thing is color and shine, depth is assumed if the first two factors are correct.
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    July 2005
Posted by Lloyd on Sunday, April 29, 2012 9:25 AM
Stage 1 weathering. The panel shading looks a bit strong under the flash light, but will blended and worked over with washes etc.
picture hosting
hosting images
upload pictures
adult image hosting
upload pictures
    July 2005
Posted by Lloyd on Sunday, June 3, 2012 9:43 PM
I've added the water, getting something close to what I was looking for originally. I just couldn't get this effect with silicon. This will take a month or two to dryStick out tongue
upload images
upload pictures
I modelled the water surface using the rounded ends of two sculpting tools, 'pinching' the water to get the rough surface effect. This shots shows the before and after on each side of the sub. The putty itself smell a bit like oil paint, very pleasant to work with in the end.
image hosting adult
adult upload image
hosting images
    July 2005
Posted by Lloyd on Wednesday, August 1, 2012 8:56 AM
I've painted an undercoat of royal blue acrylic paint, and airbrushed the wake and churning ocean along the subs hull. I then poured a few layers of gloss varnish across the surface.
    July 2005
Posted by Lloyd on Wednesday, August 1, 2012 9:11 AM
I added foam and cresting waves with mixtures of white acrylic, gloss gell and bicarb of soda for the 'white caps" which give a nice texture compared to the glossy water.
 img upload
    July 2005
Posted by Lloyd on Wednesday, August 1, 2012 9:14 AM
