WWII German Destroyer Color
    September 2006
Posted by shall on Thursday, July 12, 2012 11:19 PM
I'm starting my build of Dragon's 1/700 Z-39 destroyer.  The instructions say to mix 65% Flat White and 35%  Flat Black for the hull color.  I would prefer using something straight from the bottle so if I have to go back later and do some painting I don't have to worry about mixing the exact color again.  Can someone give me some Tamiya or Vallejo or even a MM color that will be close enough for a German WWII destroyer?  Ships aren't my area of expertise and the box art looks a lot lighter than what I think the above mix would turn out to be.
Thanks,
Steve
shall
    March 2007
Posted by bondoman on Friday, July 13, 2012 2:43 AM
No easy answers in this business, and even if there were, that would be no fun.
You are correct in assuming that a gray mix with no color is not going to be accurate, and for the question asked, you need to find the answer.
Here are the two best places to start in WW2 ship modeling color references.
www.shipmodels.info/.../viewtopic.php
www.shipcamouflage.com/colourcoats.htm
Posted by Don Stauffer on Friday, July 13, 2012 8:58 AM
If you are going for something close, go with something a bit lighter.  Environment tends to lighten colors (chalking, bleaching, fading).  Not much darkens colors other than grime, which a wash afterwards may do better than a solid color effect.
    September 2006
Posted by shall on Friday, July 13, 2012 2:46 PM
From reading the forum above it seems to me the hull and superstructure would be painted RAL 7001 and the deck RAL 7016, for which Vallejo says their 990 (Light Grey) and 995 (German Grey Dark) are matches.  Though the Paint Conversion Chart says Vallejo 870 (Medium Sea Grey) is a match for RAL 7001.  Model Master enamels 1725 (Nuetral Grey) and 2101 (Anthracite Grey) look to be good matches also.  Model Master acrylic Graublau also looks to be a good match for the hull and superstructure.
If nobody has any major contentions with what I wrote above, then that will be my starting point for painting the Z-39.
shall
    June 2012
Posted by southsideringo on Saturday, July 28, 2012 3:11 AM
What I do is mix up a sizable batch of my mixture paint into a pimento jar.  Mix it up real good, use it, put the lid on, and pop it in the fridge.  It can last for weeks.  I learned this trying to do glue-ups in my wood shop in the winter.  The glue just would not set up.  Things like glue and paint need two things to set up, heat and oxygen.  So deprive your mixture of both.
W
    June 2012
Posted by southsideringo on Saturday, July 28, 2012 3:12 AM
I think I should have said "air" not oxygen.
    September 2005
Posted by warshipguy on Monday, July 30, 2012 8:20 AM
There is a nice guide at the following address. The article is titled "Kriegsmarine U-Boat Colors and Markings" by Dougie Martindale, but it gets into surface ships as well. I just did a search under the title of the article and it came right up.
Also, you could try the Lifecolors Kriegsmarine paints available at Pacific Front Hobbies online, the naval wing of Freetime Hobbies.
www.artitec.nl/downloads/instructions/uboat/uboat...
Bill
