Glossy Masts?
    March 2012
Glossy Masts?
Posted by David_K on Thursday, July 26, 2012 9:21 AM
Hi all-
So I was walking through the Northlake Shipyard in Seattle yesterday, happened to look up and notice an old-time, wooden mast hanging from some rafters.  It was glossy, as if coated with a clear lacquer, or some other sealant.
It got me wondering, were old sailship masts glossy?  Most of the surfaces on my current project are flat, earthy colors....but if there are certain parts (masts, for example) that should be shiny, I'll consider applying some Future or something?
Thanks
        _~
     _~ )_)_~
     )_))_))_)
     _!__!__!_
     (_D_P_K_)
Current Project:  Imai/ERTL Spanish Galleon #2
Recently Finished: Revell 1/96 Cutty Sark
Next Up:  ???
Posted by Don Stauffer on Friday, July 27, 2012 9:08 AM
Yes, they originally were glossy, either gloss paint or varnish (really old ones may have just been oiled).  But they only stayed that way for a short period, as sunlight has a bad effect on paints and varnishes used on period ships.  Even most paints today go dull and chalk in sunlight, except for fancy catalyzed paints.  Once built, ships are exposed to elements all day every day.
    March 2012
Posted by David_K on Friday, July 27, 2012 9:27 AM
Thanks for the info, Don!  Maybe I'l just leave my masts the way they are....
        _~
     _~ )_)_~
     )_))_))_)
     _!__!__!_
     (_D_P_K_)
Next Up:  ???
    March 2012
Posted by David_K on Friday, July 27, 2012 11:47 AM
Anyway, here's a couple of pics of the mast I saw...in case anybody's interested...I thought it was cool! mast1 mast2 mast3
        _~
     _~ )_)_~
     )_))_))_)
     _!__!__!_
     (_D_P_K_)
Next Up:  ???
    March 2007
Posted by bondoman on Friday, July 27, 2012 6:52 PM
That is a sailboat mast.
Posted by CapnMac82 on Sunday, July 29, 2012 5:21 PM
In model form, I find a full gloss best for depicting a metal mast (that an and under-coat of silver.
For wooden masts, only a semi-gloss, and then on unpainted surfaces, to represent the finishes used to protect the unpainted wood.
Don's observations on how finish would weather are, as always, apt.  To add to that, the unpainted portions of masts were left that way as the movement of the parrels of the yards up and down the masts would wear away paint.
That, and scale effect, are both reasons to tone-down any gloss used.
Now, an exception to that is in painted iron.  Ironwork was given a glossy black mixture to protect the iron and to inhibit rust.  This is glossy are quite large distances (and can look like a flood of Future or Acrylic resin up close).
Posted by CapnMac82 on Sunday, July 29, 2012 5:29 PM
If I had to guess, that spar is a jib-boom, like as not.
If only from the lack of fittings (for cheeks, trestle-trees, etc.), and for what looks to be one sheave set into the white-painted portion.
Could be a mast for a gaff rig, but, there's no shelf for jaws nor gooseneck for a boom.
Probably not a boom, either, for not having stops for sheets, in and out hauls, lifts and the like.
Probably not a topmast, either, if for lack of a hoisting sheave near the heel (and that doublings are almost always painted).
