Warning! Warning!
No pictures either,hmmph! Well,anyway.I just started this model and ran across something I thought I would pass along.Although the kit is molded well there are two very glaring flaws in the hull. you will notice them straight off.There is a very large ejector pin mark on the outside of the hull ,on the model, dead midships on the bottom.
This thing is humongous! 1/4 across!! Then the other thing is the fit of the deck to the hull.The little teensy stations that are supposed to hold up the deck and locate it within the hull are so tiny and spaced so far apart that the deck CANNOT be put on correctly.And at the bow,the deck requires filler at the edge! There,s no way around that either! There ,you are warned ! good building------TANKER-builder p.s. the stand is to small too !
