I had mentioned in another forum about a week ago (subject workbench mods) an auxillary workstand that I use a lot for rigging. This is a homemade stand adjustable for height, which is nice for rigging (my workbench is a fixed height. The stand is made from two sizes of PVC drain pipe. One fits down inside the other. I have holes drilled every inch in the outer piece, and I put a long bolt through a pair of these holes to set the height. Allows me to rig top of mast areas without holding my arms way up in the air (and I can see better).
looks liek a good idea, save your arms from being fatigued from holding them up so long too!
"Superiority is our priority"
Excellent idea, thanks for sharing. Does the table portion also pivot?
Lon-ski
f8sader Excellent idea, thanks for sharing. Does the table portion also pivot?
Yes. I made a plywood plug for the top tube, and a half inch bolt goes through the trough, through that plug, and fastened with a stopnut so I could put some friction tension on the bolt and have it hold that tension.
