A TRICKY MANEUVER
    August 2008
A TRICKY MANEUVER
Posted by tankerbuilder on Wednesday, March 6, 2013 8:43 AM
How many of you can draw fairly well ?
   There is a reason I ask this .With All the aftermarket wood decks coming down the pipe (and the wow ! prices too ) I have tried something . Hmm
 This is an experiment so no pictures .Take the THINNEST BASSWOOD you can get . Draw lines on it with a technical pen that draftsmen used to use . Keep your lines straight with a steel rule and make sure they are PROPERLY spaced for the scale of the ship you are doing it for .Wink
  Now while you have the full piece of wood lined ,go back and measure the plank length (the break lines you see ) and put in the lines that cross the deck every other plank .This is NOT easy . When done buff lightly with a 2000 0r 4000 type steel wool pad .This will remove fuzzies and tone down the lines .Cool
  Now , coat the deck with ANY craft clearcoat in flat ! After this , make paper patterns and transfer this to your wood ,make light but accurate lines .Cut out and mount on the ship with thinned contact cement applied to both surfaces and allowed to dry to the touch . Yes
  This sounds hard but it isn't believe me .This will save money and allow you to use wood on any ship that requires it . Just remember , keep your wood VERY thin . I have even used the veneer that you use to finish a shelf or countertop edge and it works . As to the heat they say you should use .Well , use a hair dryer set on heat one .Very light heat , and wave it past the part ,  and keep it moving while pressing it in place with a burnishing tool . Yes
   This is why I said it was an experiment .I used " Glue Bombs " to teach myself the technique . It does work and can give you a beautiful wooden deck .I started using this technique on sailing ships years ago and NEVER gave modern warships a glance .Now , that it is something folks want to do , " Go For It " Captain    Tanker-builder
Posted by Don Stauffer on Wednesday, March 6, 2013 9:08 AM
Midwest sells pre-scribed basswood in 1/32 inch (and other thicknesses)  with black lines already on it. It looks like they take sheets of whatever plank width the stuff is as thickness, darken the faces of the sheets, glue them together, and then shave off sheets at right angles,  of the thickness spec.  It is quite a bit more expensive than their plane basswood or basswood with the deck lines merely scribed, but it sure looks nice.
    August 2008
Posted by tankerbuilder on Wednesday, March 6, 2013 12:09 PM
YEAH ;
You are right DON .I tried one once and it worked out well .Again it was a lack of funds that drove me to what I did . Being retired,sometimes drives you to develop new methods when and where needed .I still have some of the Basswood you speak of and it,s for the old style REVELL ships . I will probably use it this summer .        Tanker-builder
