Bronco German Type XXIII sub in-box review
    August 2006
Posted by Sauron on Saturday, March 30, 2013 10:01 AM
I just received the new Bronco 1/35 scale German Type XXIII sub kit and thought you might like to see what's in the box.
 The first thing you notice is that the box is full and well packaged.  All parts and sprues are in plastic bags.  The hull halves are held together with rubber bands, two small ones and three large ones.  The large ones will probably come in handy when joining the halves together.
 There are 8 parts sprues plus one for the sail and a small one of clear parts.  There is also a length of string, two magnets for the torpedo doors, and a sheet of PE parts, and decals.  Everything is molded in a light grey plastic.  Also included is a 'bonus' sprue for a rubber lifeboat.  There is no flash but the sprue attachment points on the hull and sail pieces are thick and will require a bit of work to remove cleanly.
 The instruction booklet is 8 pages and includes color and decal guides for 5 options.  There is a small ammendment sheet with a correction to step 9 and an 8”x17” poster of the box cover art.
 This puppy is BIG, over 36” long but despite the size the hull pieces show no warping.  This may be due to how thick they are and some internal bracing.
 The big surprise though is the surface detail.  All the welded hull seams and riviting are crisp and very detailed.  Even the steel plates appear to have some texture.  The torpedoes and the lifeboat are nicely done as well.
 All in all this looks like it will be a fun build with few problems and will certainly be impressive on the shelf next to the 1/35 Schnellboot S-100 or in a diorama with four sections of the Italeri Long Dock kit.
Cheers,
Rick G.
"One Ring to Rule Them All, One Ring to Find Them, One Ring to Bring Them All, and in the Darkness Bind Them."
    March 2004
Posted by subfixer on Saturday, March 30, 2013 10:10 AM
Wow! When do you start?
I'm from the government and I'm here to help.
    August 2005
Posted by Tracy White on Saturday, March 30, 2013 10:04 PM
Some people have reported warping in the aft sections, which lack the internal stiffeners.
Tracy White Researcher@Large
    August 2006
Posted by Sauron on Sunday, March 31, 2013 8:25 AM
Tracy, I did a dry fit of the whole hull and mine seems to be OK.  I can see how if would be hard to correct though.  The plastic is pretty thick and rigid even without the bracing.
Subfixer, this will probably be a winter build for me.  I had a wild thought about it last night (maybe it was the Jack D) that you could build two half-hull models to hang on the wall.  One would be the exterior and the other would have a scratch built interior.  Right now I'm leaning toward the diorama idea.
Rick G.
    March 2004
Posted by subfixer on Sunday, March 31, 2013 10:18 AM
That half model on the wall idea sounds pretty dang good.
