Gluing Painted Surfaces
    May 2006
Posted by Spotted Dog on Thursday, April 25, 2013 11:39 AM
I am finally finishing Revell's 1/96th Constitution & am looking forward to starting on my Heller kit of the Victory. Hopefully I won't repeat some of the mistakes I made on the Constitution. One area I need help on is gluing the cannons on the main deck. The deck needs to be painted but I had issues with the cannons coming loose. Should I mask off the various areas where the cannons will be located then touch up after they are placed? Any suggestions would be appreciated.
Spotted Dog
    November 2010
Posted by Bigb123 on Thursday, April 25, 2013 12:26 PM
I'd paint the deck and cannons separately, then use small drops of superglue on each cannon carriage wheel to attach them to the deck.  Touch up shiny spots where the superglue has dried with dullcote applied with a detail brush.
    July 2012
Posted by littletimmy on Thursday, April 25, 2013 2:13 PM
The hard way would be to drill holes in the base or wheels of each cannon and then drill matching holes in the deck . Use a piece of wire glued into the holes in the cannon and leave about 1/16th of an inch sticking out. Glue that into the holes in the deck and those cannon will NEVER move again.
Works on " pesky" cats too !
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
    April 2005
Posted by ddp59 on Thursday, April 25, 2013 7:30 PM
if have a cannon assembled, put down masking tape or painters tape down were the cannons are going to be then trace out the outline of the cannon's wheels. once traced out, cut out the rest of the tape except for the 4 tabs of tape were the wheels will eventually sit. paint the deck(s) then pull off the tabs of tape so can be ready to have the cannon wheels glued to those bare spots on the deck(s).
    April 2006
Posted by waynec on Thursday, April 25, 2013 10:09 PM
with superglue, if there is an obvious overflow you might be able to clean it up with debonder on a q-tip. this won't work if the area is painted.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
Posted by Don Stauffer on Friday, April 26, 2013 9:02 AM
I run the carriages over a sheet of sandpaper held to a flat block.  That sands the paint off the tip of the wheels.  Then I drill small holes in the deck, like littletimmy.  For that scale I do not need the wire support.  I don't drill the holes very deep, just making a V-shaped impression to get through the paint.  Make a little template from a piece of cardboard to make drilling easy.
    May 2006
Posted by Spotted Dog on Tuesday, April 30, 2013 1:24 PM
Thanks for the suggestions. I'll give them a try.
Spotted Dog
