Could you ID this thing?
    July 2008
Posted by castelnuovo on Tuesday, May 14, 2013 1:18 AM
This is USS California and the "thing" is that clock like object on the front mast, just under the lookout structure. Does anybody know what it is?
Thanks...
    September 2012
Posted by GMorrison on Tuesday, May 14, 2013 1:48 AM
It's called a range clock. It's not a time piece, but a signal to the distance in thousands of yards to the target. That was pretty common up until around Pearl Harbor.
Usually there was another one pointed aft. They had a small hand (10,000 yards) and a large hand (1,000 yards).
There was also a device on board correctly called a range clock that was more closely just that, but that's a more complicated story that indicates the arrival of fire control.
    August 2005
Posted by EdGrune on Tuesday, May 14, 2013 6:44 AM
And if you look closely at the "B" turret you will see a black band with numbers.   This is to indicate the bearing which the turret is firing.    The bearing band id on fore & aft turrets and along with the range clock information allows concentration of fire of the battle line.
    July 2008
Posted by castelnuovo on Wednesday, May 15, 2013 5:36 PM
Thank you gentlemen.
Cheers...
    August 2005
Posted by Tracy White on Thursday, May 16, 2013 5:40 PM
Also known as concentration dial.
Tracy White Researcher@Large
