My first ship build Is Done!!
    August 2013
Posted by Jsmyth on Thursday, August 29, 2013 4:43 PM
Here are some photos of my Revell 1/426 USS Arizona Build. Working on my skills to build Academy's 1/350 USS Indiianapolis.
    September 2012
Posted by GMorrison on Thursday, August 29, 2013 7:44 PM
Looks very clean. I think the CA-35 would be a good choice. It will keep you busy for a while. I have not built it,but my experience with Academy kits has been positive.
The kit you show points out why the use of photo etched details used to be so much harder than it is today. Kits now generally are designed without much in the way of cast on detail that would have to be removed, like those railings.
Take a look at the T-2 that Fred just completed. All of those etched railings involved taking off cast ones first.
    September 2003
Posted by checkmateking02 on Thursday, August 29, 2013 9:30 PM
That looks pretty sharp.  What type paint did you use?
    July 2010
Posted by docidle on Thursday, August 29, 2013 11:18 PM
Looking good J, keep up the good work.  I am looking forward to your Indianapolis build as I have my eye on that and the San Francisco for an in between build.
Steve
    August 2013
Posted by Jsmyth on Friday, August 30, 2013 6:17 AM
Checkmate I use mostly acrylic paints from Tamiya and Modelmaster. As I build I keep finding out I need more tools and supplies so I try to make do with what I have.
Thank you all for the input and I will keep posting my progress.
Posted by Don Stauffer on Friday, August 30, 2013 9:15 AM
Very nice!  If this is your first ship build, I sure want to see some of the succeeding ones!
    March 2006
Posted by TD4438 on Friday, August 30, 2013 9:16 AM
Nice clean job so far.You're doing fine.Keep those pics coming.
    August 2013
Posted by Jsmyth on Friday, August 30, 2013 8:01 PM
Here is a quick up date of the work done today. I painted the black belt line but I'm going to have to touch it up due to some bleed through. I also worked on the main mast. Time to learn hoe to scratch build due to the fact I broke the antenna. UGH!
    April 2005
Posted by ddp59 on Friday, August 30, 2013 8:38 PM
how are you going to put the rudder on if you glued the hull together without the rudder sandwiched in between the 2 hull halves?
    August 2013
Posted by Jsmyth on Friday, August 30, 2013 9:10 PM
I lost the rudder that came with the kit. So I'm going to have to scratch build one from a old credit card or something like that. I was thinking on using a peice of rod then super glue the rudder to it after that.
    August 2013
Posted by Jsmyth on Saturday, August 31, 2013 5:15 PM
Here are some more pics. I had to learn how to scratch build. I broke off the antenna off frome the main mast and lost the rudder as well.
    March 2009
Posted by surfsup on Saturday, August 31, 2013 11:07 PM
For your first Ship you are doing a very nice job of her.....Cheers mark
If i was your wife, i'd poison your tea! If Iwas your husband, I would drink it! WINSTON CHURCHILL
    August 2013
Posted by Jsmyth on Monday, September 2, 2013 2:00 PM
Getting close to the end! I have been busy on this long weekend. I was having a hard time on deciding on what color to paint the life boats so I went with the hull color.
    June 2006
Posted by Paul5910 on Tuesday, September 3, 2013 4:55 AM
Outstanding job with her!  And extra thanks for the pictures too.
Paul
    August 2013
Posted by Jsmyth on Wednesday, September 4, 2013 6:08 AM
I need some input on how and what to use for the rigging on this ship. Keep in mind it is my first ship build. I look forward to everyone's input.
Thank you
    September 2012
Posted by GMorrison on Wednesday, September 4, 2013 4:11 PM
You have a range of choices. Lately I've tried a thread called EZ Line. It's pretty cool stuff. It is elastic to several times it's original length, it is black, and it superglues well. Drill a tiny hole, like a "50" for one end, stick it in and touch with a tiny bit of glue on a toothpick tip. Pull just a little and either wrap the other end around where it goes or just hold it against that point and glue it again. Almost right away you can let go, and trim later. I can fly along with the stuff. It is scale too thick for this ship, but anything scale would be pretty invisible.
Also once installed, you can snag it with tools or fingers and it stretches and returns rather than snaps off.
Oh, and work from the inside out.
    August 2013
Posted by Jsmyth on Wednesday, September 4, 2013 9:19 PM
Thanks for the input. I will have to pick up some of that line for my next build. I had a heck of a time with the thread. i did drill holes as needed. I'm so close to the finnish! Here are some more pics for you all to enjoy.
    August 2013
Posted by Jsmyth on Thursday, September 5, 2013 5:10 PM
Well here is the final product. I had fun, anger, and many more feelings. I learned alot and thank you all for the great advise. Share your comments good and bad.
    September 2012
Posted by GMorrison on Thursday, September 5, 2013 5:45 PM
Looks really good. She needs a proper base.
    August 2008
Posted by tankerbuilder on Tuesday, September 10, 2013 9:05 AM
hello :
 Now , heres a real , no b.s. critique . You did a darned fine job .I don't remember how many of those I have done , but I think the number is now seven .Folks seem to like her sooo . I like the way you handled the whole job and you showed that if a part is broken , it's  not the end of the world or the build . I congratulate you for a job " Well Done " . Now where did I put that conversion to the Pennsylvania  ?   Thanks for the photos too .   Tanker - Builder
    March 2006
Posted by TD4438 on Tuesday, September 10, 2013 10:47 AM
No lack of effort here!
Well done.
I must admit I wouldn't mind building this kit again.
    August 2013
Posted by Jsmyth on Wednesday, September 11, 2013 7:44 PM
Thank you all for the comments. I really learned alot with this build. I'm starting a quick build of the Revell USS Missouri. This kit has got to be one of the worst mold jobs i have ever seen. Onec this is done i will be starting Academy's USS Indianapolis with no PE then the build I have been working up to. Big Mamie the USS Massachusetts from Trumpeter. Once again thank you all for your input and I look forward to sharing more builds.
    June 2004
Posted by seasick on Wednesday, September 11, 2013 8:45 PM
Excellent build!
Chasing the ultimate build.
    April 2005
Posted by ddp59 on Wednesday, September 11, 2013 8:51 PM
tankerbuilder, what version are you going to do the pennsylvania, pre-pearl harbor or post?
    May 2004
Posted by f8sader on Thursday, September 12, 2013 12:39 AM
Good work, you got her done!  I built that same kit at 12, it was boxed as the USS Pennsylvania when I built it.  Haven't seen the molded on detail since I went off to join the Coast Guard in 1975!  I had a younger brother who I'm sure took care of a proper burial for it while I was away at boot camp.
Lon-ski
    June 2013
Posted by RobGroot4 on Sunday, November 3, 2013 7:10 PM
Fantastic job!
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    August 2008
Posted by tankerbuilder on Wednesday, November 13, 2013 1:42 PM
Hi :
  I am still up in the air about that , Probably post Pearl Harbor .
