Kongo, DDG-173, Trumpeter 1/350 Kit #04532 OOB Review and Build
    July 2012
Posted by Jeff Head on Friday, October 18, 2013 2:53 PM
My Review and Build of Trumperer's 1/350 scale Kit #04532,
JMSDF DDG-173 Kongo, AEGIS Destroyer
Introduction and What's in the Box - October 17, 2013
Overview - The JMSDF Kongo Class:
The Kongo Class AEGIS destroyer class is the core of the Japanese Maritime Self-Defense Force (JMSDF) destroyer flotilla organization. There are four of these larger AEGIS guided missile destroyers and you will find one of them in each flotilla. They were built from the US NAvy Arleigh Burke Destroyer Flight I design, though there are some differences.
Each of these vessels displaces 9,500 tons full-load, and up until the contruction of the follow-on Atago Class (which were based on the US NAvy Arliegh Burke Flight IIA design), and then the Hyuga helicopter carriers and now the Izumo helicopter carrier after them, they were the largest warships built by Japan since World War II.
Each of these vessels is heavily armed and acts as a flotilla leader, or as escort to JApan's capitol vessels. Their armament includes:
  • 1 x 127mm 54 cal DP main gun
  • 2 x Mk-41 VLS Launchers for 90 missiles
  • SM-2MR AAM, SM-3 AAM, and RUM-139 VL ASROC missiles
  • 8 x Harpoon Surface to surface Missiles
  • 2 x 20mm Phalanx CIWS
  • 2 x Type 68 Triple torpedo launchers
Four vessels were built and have been commisisoned and are fulfilling this role:
DDG-173 Kongo, Laid down on May 8, 1990, launched on September 26, 1991, and commissioned on March 25, 1993.
DDG-174 Kirishima, Laid down on April 7, 1992, launched on August 19, 1993, and commissioned on March 16, 1995.
DDG-175 Myoko, Laid down on April 8, 1993, launched on October 5, 1994, and commissioned on March 14, 1996.
DDG-176 Chokai, Laid down on May 29, 1995, launched on August 27, 1996, and commissioned on March 20, 1998.
All four are powerd by by four Ishikawajima-Harima LM2500 gas turbines which give them a top speed of in excess of 31 knots.
The superstructure of each is dominated by the SPY-1 phased array radar, which are fixed, radars facing in each of four directions providing 360 degree coverage without a rotating radar. The design of the superstructure also incorporates stealth features, designed to reduce radar cross section of the ships. As a consequence, the ship is somewhat more top-heavy than other destroyers and requires a deeper draft. As such, operations in a littoral (coastal) environment are limited. They have a high top speed and are suprisingly manueverable, and because of thier large displacement actually come close to the size of traditional cruisers than destroyers. All four have been built are built to operational requirements allowing them to operate as a flotilla or squadron command vessel.
The Kongo destroyers have been modified over their history for modernization and to assume additional roles. One of the most important of these has been to serve in a theater ballistic missile defense role. Due the proliferation of short to medium range ballistic missiles, adopting this role and using the US developed systems and weapons (as the US does on its Arleigh Burke class destroyers) was a natural evolution to help protect the Japanese islands from this threat.
In December 2007, Japan conducted a successful test of the SM-3 block IA against a ballistic missile aboard JDS Kong? (DDG-173). This was the first time a Japanese ship was selected to launch the interceptor missile during a test of the Aegis Ballistic Missile Defense System. In previous tests they provided tracking and communications. Afterward, Japan has also undertaken another two successful Ballistic Missile Defense test aboard JDS My?k? in October 2009 and aboard JDS Kirishima in October 2010.
These vessels will remain the center pieces for JMSDF flotilla operations for the next several decades. With the addition of the Atago class, the Hyuga class DDH vessels, and the new Izumo DDH vessels, that role has only taken on more importance.
What's in the Box:
The 1/350 scale Trumpeter model of the JS Kongo, DDG 173, kit #04532, is an exccellet, detailed depiction of the vessel. It is molded in gray and hull red plastic, and can be depitcted in either a full hull, or waterline version. This model will be built with the full hull. Trumpeter is very well known for its quality producs and modern manufacturing techniques.
Inside the box, you find the hull in two pieces, one to be used for the waterline, with a plate to attach to its bottom, and the other to add to the above waterline portion to show the full hull. This lower section is molded in a hull red, though not exactly the color I will use for the blow waterline portion. There is a full length, highly detailed main deck to match to it. All are molded very well with little or no flash or extra plastic left over form the molding process.
There are 7 sprues of gray plasic parts, and one sprue of clear plastic parts (the helicopter). Altogether there are well in excess of 300 parts to the model. There are no photo etch parts included with this model. I will be using a Tom's Model Works, 1/350 scale photo etched railing set for this model. The plastic parts are extremely detailed and the include the sensors, vents, tie downs, and other small parts in very good detail so photo ecth parts for them do not appear to be necessary.
A very good set of waterslide decals with over 50 decals is included which covers all of the flight deck markings, all of the helo markings, and the pennant numbers and various hull and superstructure markings. There is a very nice full-color sheet of the Takinami in multiple views for painting, including several of the most common paint suppliers part numbers for the paint.
The instruction sheet is, as is the case with all newer Trumpeter models, very intuitive and well laid out. it is 16 pages lon and covers all of the build, including all options for the modeler (ie. like whether to make a waterline build or not).
Here is the instruction sheet.
This looks to be a great build, particularly with the addition of the photo etch parts form Tom's Model works. The Kong will make an outstanding addition to my JMSDF Carrier group cenbtered on the JS Hyuga, DDH-181, that I recently completed.
Next I will go through and paint all of the horizontal parts in neutral gray, the lower hull in a hull red, and the main deck and weather decks in flat gray. The Mk-41 VLS systems will be painted in a dark ghost gray, and I will use flat white for the radar domes and life boats, flat black for the waterline mark and the funnels, and various other shaeds of grays for other sensors and the ships launches per pictures of the vessel itself.
SCHEDULE for Future Activities - October 17, 2013
  1. By Nov 15, 2013: Complete the JMSDF Kongo AEGIS DDG.
  2. By Dec 31, 2013: Start the French Carrier Group centered on Heller's Charles de Gaulle with two DDGs and an FFG.
  3. By Feb 31, 2014, Start the Russian Carrier Group centerd on Trumpeter's Kuznetsov with two DDGs and an SSN.
  4. By Apr 31, 2014, Start the US Navy Amphibious Ready Group centered on the Gallery USS Wasp with an LHD, an LPD, a DDG, a SSN and a LCS.
The completion of the PLAN Carrier group, centered on the already completed Trumpeter's 1/350 scale PLA Navy's Aircraft Carrier CV-16, Liaoning, (in addition to the other escorts already completed) included Mini Hobby's's PLAN Guangzhou, DDG-168. I recently pre-ordered a 1/350 scale model of the PLAN Type 071 LPD, Yuzhao Class, announced by Trumpeter and due out in October, 2013. I will end up adding two of those, propbably LPD-998 Yuzhao and LPD-999, Jinggangshan, add the PLAN- DDG-139, Ningbo, and the PLAN DDG-115, Shenyang, along with the PLAN Weifang, FFG-550 and thus build a PLAN ARG.
The completion of the US Carrier Strike group, centered on the completed Tamyia's 1/350 scale USS Enterprise, CVN-65, (in addition ot the other escorts already completed) included Trumpeter's, USS Freedom, LCS-1, Dragon's USS Preble, DDG-88 and Hobby Boss's USS Texas, SSN-775. When a 1/350 scale USS Enterprise, CVN-80 (or any Gerald R. Ford Class) is released from Trumpeter, Tamiya, Dragon, or whomever else, I will add it to this group along with another AEGIS Cruiser. Whichever Ford Class coms out in 1/350 scale, I will build it as the USS Enterprise, CVN-80.
The US ARG will include Tamiya's 1/350 scale, USS Iowa, BB-62(which I have already completed), Trumpeter's 1/350 scale USS Iwo Jima LHD-7, Gallery's 1/350 scale USS Sommerset, LPD-25, Bronco Models 1/350 Scale USS New York, LPD-21, Cyber Hobby's USS Independence, LCS-2, Acadamy's 1/350 scale USS Rueben James, FFG-57, and another Flight IIA US AEGIS class detroyer based on Trumpeter's 1/350 scale USS Lassen, DDG-82...all of these models which I already own.
The UK Group features the Airfix 1/350 scale HMS Illustrious, R06as its centerp[iece until a 1/350 scale Queen Elizabeth carrier is released. When that happens, I will add that carrier to the group as its centerpiece. The Roylal NAvy CSG will also include two Airfix 1/350 scale Daring Class DDGs (one of which is already completed), two Trumpeter 1/350 scale Type 23 HMS Duke class Frigates (one of which is already completed), and the Hobby Boss 1/350 scale HMS Astute SSN (which is also already completed) and Airfix 1/350 scale HMS Tragalgar SSN. One day, when a 1/350 scale HMS Ocean LPD come out, I will use tt to start building a Royal Navy ARG.
The French CSG will be centered on Heller's 1/400 scale Charles De Gualle (which I already own). I have purchased the 1/400 scale Heller French De Grasse, D612 DDG, which is an ASW DDG, the French Duquesne, D603 DDG which is an anti-air multi-purpose DDG, and the French Aconit F713 FFG and Gueprattet F714 FFGs, both of which are Lafayette class frigates. These five vessels will round out my French CSG. As soon as a French Robin class nuclear sub, like the French Perale S606 SSN is released in 1/350 or 1/400 scale, I will add that to the group. Also as soon as the Forbin D620, Horizon class anti-air DDG is released in 1/350 or 1/400 scale, I will purchase two of them and replace the De Grrasse and Duquesne with them, and then save those two for when a Mistral Class LPD is released in 1/350 or 1/400 scale so I can create a French ARG with those vessels.
The Japanese JMSDF group is centered on Fujimi's very finely detailed, 1/350 scale Hyuga, DDH-181. It will be escorted by Trumpeter's 1/350 scale DDG-177, Atago, an AEGIS class DDG and the JMSDF, DDG-174, Kongo class (which I own), Trumpeters's 1/350 scale DDG-114 Susunami and DDG-111 (both of which are Takinami Class DDGs which I own), and by the 1/350 scale SS-503 Hakuryu (which I own), one of Japans new, very modern and capable AIP Diesel Electric submarines. As soon as a DDG-115 Akizuki in 1/350 scale is released, I will add it to this group. Should a 1/350 scale Osumi Class LPD be relased, I will buy two of those vessels and create a JMSDF ARG.
Then, finally it will be a complete Russian CSG (centered on Trumpeter's Kuznetsov which I own) the Russian Slava Class cruiser, Varyag by Trumperter (which I own), two Trumpeter 1/350 scale Udaloy DDGs (which I own), Hobby Boss's Akula II class SSN (which I own), and the new Yasen class Russian SSN which I own in 1/350 scale. Some time in the more distant future when a 1/350 scale Russian version of the French Mistral class comes out (which is building in real life right now), I will add two of those and build a Russian ARG.
Recently I purchased Heller's 1/400 scale Foch, the Clemceau Class carrier that was sold to the Brazilians in 2000 and in 2002 was refitted and became the Brazilian CV, Sao Paulo, using steam catapaults. I will build the model as the Sao Paulo and thus start a Brazilian group, though the Type 22 DDGs and the FFGs the Brazilians use are not available at present. I have however purchased a set of 1/400 scale A-4 Skyhawks and S-3 Trackers to build a suitable airwing for the Sao Paulo.
Then, again, once the models are available, I'd like to build an Italian Carrier Strike Group centered on the Cavour and their Horizon DDGs, a Spanish Carrier Strike Group centered on the Juan Carlos and their F-100 AEGIS FFGs, and ultimatly an Australian Strike Group centered on the new Canberra Class LPD and the Hobart class AEGIS DDGs. If they ever build the models, an Indian Carrier Strike Group centered on either the Vikramaditya or their new ADS Carrier, the Vikrant, and their Kolkata class DDGs and Shivlak class FFGs would also be nice.
Years more worth of work!
You can see all of these actual carriers, read their histories and specifictions at my site:
WORLD-WIDE AIRCRAFT CARRIERS
...and most of their surface escorts at:
AEGIS AND AEGIS-LIKE VESSELS OF THE WORLD
    July 2012
Posted by Jeff Head on Monday, October 21, 2013 10:21 AM
The Build - Intial Part painting, Hull build, Fore and Aft Deck House builds - October 21, 2013
To begin with I usually paint all of the parts on the sprues (for the most part) the main color for the vertical surfaces...in this case neutral gray. I use my sprue cutters to cut away all but a single attachment to the parts (and try to make that attackement one that does not bear on any othetr surface if possible. This lessens the need for touch up painting. So, I did the nuetral gray vertical surfaces which are the most abundant surfaces on the vessel. I then added the sonar dome to the bow of the lower hull, and then painted the waterline mark on the upper hull.
Then I painted the rest of the parts, starting with the flat gray weather decks (the second most numerous parts to be painted), the hull red (for the lower hull, rudders, shaft and supports), the gunship gray and engine gray parts, the white parts for the radar domes and life rafts, etc. After these were painted and dried, I attached the upper and lower hulls, and then attached the main deck to the hull.
At this point I add the main deck decals since if you wait until later, the gun mounts, ships boats and davits, various sensors, etc, would get in the way later and make adding them MUCH more difficult to add. So, I added the decals around the main gun mount, which included the forward vert rep position, and then the helo landing deck decals aft (there is no hanger on the Kong class destroyers), and the weather deck walk way markers.
Now it was time to start building the forward main deck house which houses the bridge, the APARS and the forward smoke stack. There are 45 parts for this structure alone (not including all the details to be added later like the main mast, the numerous sensors, CIWS, and other parts). The fit on these parts is important, so I always use my exacto knife, or where necessary my dremel tools to ensure that the attachment points where these parts were cut off of the sprue are shaved or graound down carefull to make the fit flush. To ensure that any small protusions are gone that would otherwise interefere with a flush fit. This is actually important on pretty much all of the parts.
Once I did this and built those structures, I glued them together and let them dry, and then attached them (without all of the details) to the main deck.
I then repetaed the above process for the aft deck house which houses the aft missile controlers and the aft smoke stack. Once they were built and assembled, I then attached them to the main deck as well.
Now, she's looking like a JMSDF Kongo Class AEGIS destroyer. Still lots of work to do. First I will do some touch up on the deck houses, filling in some gaps with pudduy, letting it dry, sanding it down and then painting those seams. Then, I will add the rudders, shafts, supports and props next, and then begin adding all the many, many details to the decks and then to the deck houses.
    March 2013
Posted by adam340 on Tuesday, October 22, 2013 5:08 PM
I'm thinking of buying this model, how would you rate it on difficulty. Is paint and cement needed?
    July 2009
Posted by Harquebus on Wednesday, October 23, 2013 6:18 AM
Judging by the nature of your comments, I would reckon that you are a novice builder. From that standpoint and strictly speaking, one does not *need* paint for the model (as it is molded in color) but cement is certainly needed--it is not a snap together kit. It looks to be intended for advanced modelers on account of the multitude of parts. I would recommend paint though as it makes the model much more realistic looking and conceals the shininess of the plastic.
    July 2012
Posted by Jeff Head on Wednesday, October 23, 2013 9:27 PM
Well, Adam, the model itself is not all that difficult. It does have a lot of parts, and many of them are quite small.  If you are patient and can follow instructions, it will go together very well.
Yes, you will most definitely need model cement, and a number of paints in order to make the model look at all realistic.  I use Model Master paints and usually call out the actual paints I use in these builds.
I would suggest several things that will help you build the model:
1) A pair of plastic sprue cutters.  These are like fine wire cutters and will help you get the parts off of th sprues cleanly.
2) An Xacto knife so you can smooth and trim any rough edges off of parts before putting them together.
3) A pair of fine tweezers so you can hold tiny parts and properly place them.
Also I would recommend, on the larger, longer decals, to cut them into several pieces before applying them.  You soak them in water then slide them in place.  The longer, narrow decals can easily tear and come apart if you are not extremely careful, and so cutting them into 2 or 3 pieces keeps that rom happening, and then you just fit them together accordingly.
Anyhow, hope that helps.  It's a very nce model and very well detailed.
Good luck.
    July 2012
Posted by Jeff Head on Monday, October 28, 2013 10:18 AM
The Build - Deck House Details, Main Mast - October 25, 2013
There are LOTS of small details for this vessel. Will make for a very realistic 1/350 scale model once they are all on there and properly painted and applied.
I started with the life bouys. These are generally painted orange on these destroyers and provide some nice color relief. They are very small and there are not too many of them (in this case 12, 6 on each side), but they do make for nice details. I then completed the Phalanx 20mm CIWS with their white rad-domes, the Harpoon missiles launchers, the chaff dispensers, some fire control devices, and the missile directors. Lots of small parts going into these verious assemblies.
> Then it was time to start the main mast. Again, this is a fairly complex assembly all by itself...a miniature model all its own. On the Kongo class they are not the single structure that is raked back at an angle like the US Burke class DDGs. These are older, traditional type masts made up of a lot of structural members that house all of the various sensors, some of the radars, communication antennae, etc. for the vessel. This round I did the basic structure and the main spars, as well as the top cap and the highest mast. One has to let the various structures dry, and also make sure they are put together with the various angles true, and normal to one another, so the other parts will add on and look correct. Straight and squared away. Using very small drops of glue at the attachment points with a reduced diameter applicator on the glue tube, and use of tweezers helps a lot, as well as cutting away any excesss plastic after cutting the parts from the sprue. An Xacto knife and sand paper suffice here, and I usually get by with a deft use of the Xacto Knife.
That's looking very good. Still some touch up paint and fill work to do, but the Kongo is starting to look like a fighting ship now.
Next round I will finish the detailing on the main mast and all of the remaining details on the main deck and the deck houses. Lots of small parts. After that it will be a finish to the rudders and props, the stand, and then the touch up paint. And finally, the session adding all of the PE railing. So, a couple of more sessions and I will finish the JMSDF JS Kongo, DDG-173.
    July 2012
Posted by Jeff Head on Monday, November 4, 2013 11:48 AM
The Build - Deck details, Rudders and Props, touch up - November 4, 2013
There were a myriad of very small parts and assemblies to put together and thn place on the main deck, and on secondary decks, of the vessel. This included davits, ships launches, tie downs, morring, various equipment, flag masts, life boat rafts and their stanchions, etc. Many of them, like the mpooring points, are extremely small and have to be handled very carefully to keep from losing them. You can see from the one picture with the parts laying there next to the tweezer, how small they are. There were like 24 of those to be place around the bow and fan tail of the vessel.
When they were all put together and placed, they add a lot of detail to the ship, and in such a way that is far betteer than these details being molded into the vessel itself. This is one of the things I like about Trumpeter models as opposed to Dragon models. You pay a little more, but the finnnished work is mor epeasing...though both companies make very good models.
Then it was time to put place the rudders, props, supports, and stabilizers on. I had previously painted these so it was a matter of cutting them off their sprue and placing them. With this vessel, the prshafts were longer than needed because there were no through holes on the prop supports. So, rather than try and drill through them, I simply cut the shafts off appropriately and glued them together as shown.
At this point it was time to do a little touch up painting. Several of the smaller pieces when cut away from the sprues showed the original sprue color along those cuts. Also, through handling the model the last couple of weeks, some of the painting had also been worn. I simply went through the vessel and touched up the black, white, ghost gray, neutral gray, and hull red (I use Tuscany for the JMSDF vessels) where needed. Once completed, the vessel is essentially complete as delivered out of the box.
She's looking very good now. Just a few more decals, and mainly all of the railing to add.
I will be using a generic Gold Medal Model 1/350 Photo Etch (PE) metal railing set for this model and hope to have those completed, and the entire model complete for my next session later this week.
    July 2012
Posted by Jeff Head on Tuesday, November 12, 2013 10:05 AM
Here's the completion of the model. Good luck with your own build!
The Build - Photo Etch metal railings, Completion - November 12, 2013
I painted the photo etch metal railing in a camoflage grey. This is a little lighter than the vertical surfaces, but allows the railing just a little contrast to show up better. I have done this on all of my JMSDF vessels.
At that point I began placing the railing. There are a lot of auxillary decks, and the runs on the main deck are long. Since I was using a generic Tom's model works photo etch set (actually two sets, one for four rail and one for five rail), each piece had to be cut to fit. it took my about three days of working a few hours here and there to do it.
Once this was completed for the entire ship, it was time to add the final two coats of dull coat. Dull coat helps cover the places where gluing the railing, or other details here at the end would otherwise give a different finish to the underlying colors over which a little glue may have covered. Thought he glue is clear when it dries for the most part, it can also cause that different finish or sheen to appear. With dull coat, it all coms out with the same finish.
Anyhow, once those coats were on and each had dried sufficently, she was finnished.
Turned out very nicely. That's the lead ship in the JMSDF Knog Class of AEGIS destroyers, DDG-173. Here's a final, full side view of the vessel:
Now it is on to the French carrier group centerewd on the R91, Charles De Gualle.
    July 2004
Posted by stikpusher on Tuesday, November 12, 2013 1:14 PM
Wow you do quick work! Under four weeks to complete a 1/350 ship of this size and complexity. Very nicely done JH!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    July 2012
Posted by Jeff Head on Tuesday, December 22, 2015 8:30 AM
stikpusher
Thanks...and sorry it took me so long to see your comment and thank you for it.
Yes, I have done many 1/350 scale, modern warships.
My goal, which I have pretty much achieved now, was to build 1/30 scle modern Carrier Strike groups for all of the major maritime powers.'
I now have entire carrier groups for:
US Navy (Built around USS Enterprise, CVN-65)
Royal Navy (Built around HMS Illustrious)
French  Navy (Built around the Charles de Gualle)
Chinese Navy (PLAN) (Built around the Liaoning, CV-16)
Russian Navy (Built around the Kuznetsov)
Japanese Navy (JMSDF) (Built around the Hyuga, DDH-181)
I also have a complete ARG built around the USS Iwo Jima LHD-7, and the USS New York, LPD-21.
Also was able to build the BRazilian Sao Paulo carrier, based on teh model of the french Fochj, which was sold to BRazil and converterd for their use.
