French Rigging 1744 vs 1770s
    January 2014
Posted by thibaultron on Monday, February 10, 2014 11:24 AM
I plan on getting the Lindberg/pyro "Jolly Rodger", which is actually the French La Flore. I have a set of plans for another French Frigate circa 1744, with a rigging diagram. My question is were there any significant changes in French rigging practices between 1744 and the 1770s which is the period of La Flore?
    May 2003
Posted by jtilley on Monday, February 10, 2014 11:46 PM
Yikes!  I suspect there were some fairly noticeable changes, but I have no idea what they may have been.  I can suggest two courses of action.  One - order the plan package for La Flore from the Association des Amis de Musee Marine.  Two - if you've got a good library nearby, see if you can get hold of the books by Jean Boudriot (the reigning expert on French 18th-century naval architecture.
In all honesty, though, if you rig the model according to your 1744 plans I don't think anybody from anywhere other than France will see anything wrong with it.  I certainly won't.
Good luck.
    September 2012
Posted by GMorrison on Tuesday, February 11, 2014 1:56 AM
In terms of rigging, it's beyond me to  comment. Only that frigates of that era (latter half of the eighteenth century) in France/ Spain and England seem to be rigged  with three sails on the masts, a spanker sail and stay sails, much like our Constitution.
But a big difference seems to be that before 1744 most French frigates in the 8 pounder class had the gun deck below the weather deck, whereas after the mid-century they were designed with a weather/ gun deck.
The Lindberg model is in the first category.
    January 2014
Posted by thibaultron on Tuesday, February 11, 2014 6:04 AM
I was hoping to avoid buying the plans, as I already have the 1744 ones, that I found.  If I can avoid spending $60 or $70, I can spend it on other models.
    September 2012
Posted by GMorrison on Tuesday, February 11, 2014 10:38 AM
I think if you follow your plans it will be without question a fine model.
    January 2014
Posted by thibaultron on Tuesday, February 11, 2014 11:33 AM
Thanks for the help, I think I'll use the plans I have. It is a small model 1/133, so I will not be going for super detail, just a good looking and reasonabley accurate model.
