La Sirine; building of
    February 2014
Posted by FRANK on Tuesday, February 25, 2014 2:02 PM
In addition to my earlier comments on Heller's La Sirine; 1/150; and those of other modelers, here is my report on building this model. Construction started: 1/25/2014; Construction completed 2/26/2014. Total "Hands On" construction time: 93 1/2 hours. (I keep a time sheet). This is about the 9th or 10th sailing ship model I have recently built. Each model is better than the preceding. However I still have a way to go to match some of the contributors to this forum. This model required 12 different color paints; 6 different thickness of thread; 4 types of glue. Some Squadron Putty was used on a few hull seams. Finished model approximately 18 inches long; 17 1/2 inches high; 8 inches beam at the main yardarm. Finished weight 16.8 oz. (I always add weight inside the hull, using pennies. General comments: A "fun" build. The instructions leave something to be desired. When stepping the masts I use a laser light to align the masts, fore and aft and a weighted string, one for each mast, hung from the ceiling of my workroom to align them in the vertical plane. The ratlines are, as usual for me, a real "pain". I used the plastic ratline rigging "machine" included in this kit and two others from past kits. I have modified them with thin pieces of wood glued across the arms of the "machine" to force the vertical and horizontal threads into contact with each other. Then I liberally brush on Elmer's White Glue first across the horizontal threads, then across the vertical threads. I always find it necessary to repeat this process several times. Even then, some of the threads do not adhere properly. Many feet, if not yards of thread, seem always wasted: (any suggestions are welcomed). On this ratline score, some time ago I purchased an Amati "Loom a Line", put it on my shelf, and then promptly forgot about it. Later I purchased another. When I finally tried to use one of them, I gave up in frustration. Now I have two. A total waste of time and money - unless I am not using them properly. The supposedly furled up sails provided with this kit look terrible, but I did use them. I usually "weather" my sails: first painting them with "Aged White" paint, and then when dry I very lightly dust/brush them with a light brown colored chalk dust. I like the patina that results. Makes the sails look like they have seen the sea. I tried to add all the running and standing rigging to this model. This required using some 70 plus rigging blocks from my spare parts collection: none were provided with this kit. I noted that this model is woefully short on providing appropriate main deck "tie downs" for much of the standing and running rigging. I should have been more careful in adding some of the rigging to the bowsprit mast and yard arms: seems that the tension pulled the assembly off the vertical. I installed only two of the anchors and threw the other two in my "spare parts" box There is insufficient room to mount the additional anchors. Also added was some scale chain from the rudder to the transom to prevent total loss of the rudder in heavy seas. I painted the ship's name, inscribed on the nameplate, using the pointy end of a toothpick. I also painted the guns a bronze color vice the black suggested. I think the bronze color looks much better. I also added oars, painted white, to the ship's boats and made the boats and the oars fast to the main deck. I reduced the size of the flags so they looked more appropriate. Seems to me that the lines of the ship's hull would be more attractive without the "birdcages" at the bow that the model called for. I have been on a ship in heavy seas and those "bird cages" would have been promptly wiped off the hull. All in all, a good building experience. Now on to the next sailing ship kit.
    December 2010
Posted by 1943Mike on Tuesday, February 25, 2014 11:14 PM
Frank,
Sounds like a nice build. How about some pictures? Smile
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    February 2014
Posted by FRANK on Wednesday, February 26, 2014 4:51 AM
I will have to figure out how to get the photos on this web site.  Any suggestions?
Posted by Don Stauffer on Wednesday, February 26, 2014 9:25 AM
In the list of forums, right near the top, is a forum on "forum help".   That is intended to mean help using forums, not using forums for help on modeling.  Anyway, that is the most common place where this question is discussed.  Ask for help, you will get help on that subject (or look at some of the previous threads asking about this).
    December 2010
Posted by 1943Mike on Wednesday, February 26, 2014 11:11 AM
Frank,
At the risk of duplicating information you may already have, here's what I would do:
1. Make sure you have an image hosting site. (i.e.: Photobucket, Flckr, Image Shack, etc., etc.) Here's a link to some free ones: http://webtrends.about.com/od/prof4/tp/Free-Image-Hosting-Sites-For-Photos.htm
2. Upload the image(s) to that site and copy the URL (right click the image for its properties and copy the URL then paste it to word pad or write it down somewhere). I'm also assuming you're working with a Windows machine - I don't know the procedure to find the URL if you're using an Apple product.
3. Once you're back to this site and you've clicked on "New Post", type your text into the window, then, when you're ready to post an image, look at the top of the text window for the icon on the bottom line, about in the middle and just to the right of a space marker which looks like a little green square with a very small + sign on its lower right corner. If you hover your mouse over it it will say "insert image". Click it and insert the URL from the image you want posted in the proper place. Of course you then have to click "insert".
I hope this is useful.
Hector Berlioz
    February 2014
Posted by FRANK on Wednesday, February 26, 2014 1:44 PM
Thanks Mike.  I hope I can follow the instructions, If not I'll ask my wife.  She seems to know more about these things than I do - I am a bit embarrassed to admit that, having been trained as an engineer: But as a old geezer, (77),  maybe I get a "pass".  What a great hobby we have.  I spend a few hours each morning on building my model sailing ships and it "makes my day". I am impressed with the model building expertise of the folks that contribute to this forum - and their great attitude and friendliness too.
    December 2010
Posted by 1943Mike on Wednesday, February 26, 2014 4:08 PM
You're welcome, Frank.
I'm a geezer as well although you have 6 years on me. The Oregon winters were something I needed to find a hobby for and I'm extremely grateful that this site exists. I was not, even as a teenager building Revell and Monogram ship and airplane models, very patient nor very talented. However, seeing the exceptional skills on view in the two areas of this site in which I have an interest (ships and aircraft) has inspired me to start again and try to learn a little more with each build.
As an adult I've built the Revell 1/96 USS Constitution (a poor job), Dragon's 1/350 Buchanan (DD-484) as the Duncan (DD-485) during which I learned a little about PE (I still need lots more practice and patience with PE), created a waterline base for the first time and was relatively pleased with the outcome, and, most recently, the Revell 1/96 Cutty Sark. I interjected a few images of my build into Rob Weiderrich's thread who did a masterful job with his CS. Mine doesn't hold a candle to his but I had fun in the building process, learned a bit and, hopefully, improved my skills a little. This page has my last post on the Cutty Sark below a couple of images of another Cutty Sark that Rob is working on: http://cs.finescale.com/fsm/modeling_subjects/f/7/p/151475/1717614.aspx#1717614
In my stash I have lots of ships to build. Among them are Heller's 1/150 Le Glorieux so I'm curious about your 1/150 Heller ship and how it turned out.
Good luck with posting images.
Hector Berlioz
