San Francisco WIP
San Francisco WIP
Posted by Don Stauffer on Monday, March 24, 2014 4:01 PM
One of the reasons I was so enchanted with the SF was the pair of big cranes and the twin catapults.  Don't have the catapults done yet, but have the crane mounted, so I thought I would show how they look.  This is using the White Ensign PE set. It is a beautiful set.  The cranes not only look nice, but they were easy to fold up and mount!  I have one catapult done and I was dreading the folding, but it turned out to be easy- very nice layout and instructions.
The base is a workbench base for building only, the model will be transferred to an oak base when it is finished.
    September 2013
Posted by Marcus McBean on Monday, March 24, 2014 6:17 PM
The cranes really did come out very nice.  The SF is shaping up really fine.
    July 2010
Posted by docidle on Monday, March 24, 2014 10:50 PM
She's looking great Don!  I have the 1942 in my stash with all the the goodies except the PE.  I was planning on using the GMM set; however, how was the WEM set?
Steve
Posted by Don Stauffer on Tuesday, March 25, 2014 9:10 AM
Nope, I misspoke!  How in the world did I ever  type white ensign!  I have the GMM set and meant to type Gold Metal.  Typos, forgotten words, and other senior moments happen more frequently as I get set to enter the fourth quarter century of my existance :-(
    February 2011
Posted by Raualduke on Tuesday, March 25, 2014 9:55 AM
Those cranes look great,you say they folded up easily ? I'm not sure I could pull that off
Posted by Don Stauffer on Wednesday, March 26, 2014 9:13 AM
Have a new question, guys.  The float planes are supposed to fit precariously on a shuttle that mounts on top of the catapult. I assume there were some tie-down lines to steady the plane tied to either that shuttle or the catapult itself.  With the PE set the only glue joint will be a small spot joining the main float to the shuttle.  I am afraid the tie-downs will have to be functional!  Anyway, I have no references on these tie-downs. I assume they were only removed when the plane was ready for launch, with engine running and pilot set.  Anyone have any references on these tie-downs for catapult planes on cruisers and battleships?
    September 2013
Posted by Marcus McBean on Wednesday, March 26, 2014 9:43 AM
The pictures I have seen shows the main float sitting in a cradle formed to hold the float/plane upright.  When the cradle stops at the end of the ramp upon launch the float of the plane shoots straight out of the cradle.  It also seems that the float may have some connectors that maybe used to lock the float to the cradle and the cradle is locked in place on launch ramp when sitting idle.
    September 2013
Posted by Marcus McBean on Wednesday, March 26, 2014 9:55 AM
I found this video on YouTube showing a how a catapult works on the USS Oklahoma. It does show a cable attached to the cradle running over the float on to the other side.  This the link www.youtube.com/watch.  I hope this helps, the video cover launch, recovery, storage.
Posted by Don Stauffer on Thursday, March 27, 2014 9:17 AM
Thanks, Marcus. Great video, though I still did not see what restrains the plane- where those cables terminate.  I am not worried about during launch. I am worried about while it is sitting in shuttle before ready to launch. If it is sitting in shuttle and the ship rolls even a little, what holds it from rolling of catapult to side. I don't believe forward motion of ship would be enough to make ailerons effective.  And I assume pilot gets into plane while on catapult, so it must be stable while he does that.  One photo I have shows a cable running from somewhere on catapult to wing float area, but doesn't show the inner end- where on catapult or shuttle does it fasten?
    September 2013
Posted by Marcus McBean on Thursday, March 27, 2014 11:26 AM
Don, this link shows a Curtiss plan on the launch with tie downs and clamps on the cradle holding the float firmly in place; www.usslittlerock.org/.../SC-1_Aircraft.html
Posted by Don Stauffer on Friday, March 28, 2014 9:15 AM
Ah, that is what I needed, Marcus!  Thanks.  That shows it mounted to the shuttle. I had kind of assumed it would be, but this confirms it- thanks again.
Posted by Tojo72 on Friday, March 28, 2014 9:20 AM
Don have you ever posted a WIP ? I can't recall unless I'm looking in the wrong sections,but I look forward to following along on this one.Looks good so far.
    September 2013
Posted by Marcus McBean on Friday, March 28, 2014 9:55 AM
I like the picture of the ship keeled over in the storm with the  plane very close to the water.
