plastic sheets like water
    November 2003
Posted by torybear on Wednesday, April 16, 2014 10:29 PM
Can someone pint me to a site that sells the plastic sheets that looks like water? Thanks
Posted by Don Stauffer on Thursday, April 17, 2014 10:24 AM
Try your local hardware or building supply store.  There are a few of those sheets that go in the light fixtures for suspended ceilings that work as water.
    November 2003
Posted by torybear on Thursday, April 17, 2014 12:24 PM
COOL...never thought about that.....been looking and found Plastruct (http://www.plastruct.com) that had this, but it is only 14 by 24......a little short for the Titanic. Thanks for your input. Mike
    November 2003
Posted by torybear on Friday, April 18, 2014 8:01 AM
Hey. Went by Lowes and loked at one of those textured light covers. Looks good and I think it will work. Only about 10.00 and plenty big for the Titanic. Great suggestion....many thanks. Mike
    August 2011
Posted by BashMonkey on Saturday, April 19, 2014 12:28 PM
I am also in need for the water like plastic for my model train layout so thanks for the tip.
 ALL OF YOUR BASE ARE BELONG TO US!
Posted by CapnMac82 on Sunday, April 20, 2014 3:14 AM
I've found that it's best to score the smooth side for cutting.  This, whether using score and snap, or using a saw of some sort.
For the former, I find a heavy utility knife a better choice than an xacto or scalper-like cutter.
For the latter, using a fine veneer blade installed "backwards" in a variable-speed saw a good choice.  This puts the teeth of the blade into the "sea" surface, so any splintering is on the back (easier to file & sand clean) side.
Truth be told, my tool of choice for the light lens sheets is a Rotozip with a laminate-cutting bit.  This, however can be kind of spendy for some one who is not going to install a lot of plastic laminate counter tops--legacy of a life time in construction for me.
