AN/SPQ-9, AN/SPG-60 and AN/SPS-52
    February 2013
Posted by Nikkie51 on Wednesday, June 11, 2014 5:22 PM
Help Any One,
I am building the 1/350 scale Adams Class DDG U.S.S. Goldsborough. It had the Mk 86 GFCS system and the SPS-52 air search radar installed it the 80’s.
Does any one know of an after market suppler that makes the AN/SPQ-9, AN/SPG-60 and AN/SPS-52 radars in 1/350 scale?
I have tried to find kits of other Classes of ships that had these radars installed with no luck there either.
    June 2004
Posted by seasick on Thursday, June 12, 2014 6:55 PM
AN/SPQ-9A came in a randome only. You could probably convert a SPG-60 from a SPG-51. The AN/SPS-52 is available as a photoetch from several vendors.  AN/SPG-60 was deployed on the Spruance, Kidd, Virginia, California, and Tarawa class ships. Gold metal models has the SPS-52 in 2 or three of its 1/350 photoetch kits. Nope.
I'll keep looking.
Tags: AN/SPG-60 , SPG-60
Chasing the ultimate build.
    February 2013
Posted by Nikkie51 on Thursday, June 12, 2014 10:58 PM
Thanks for the help!
I wish I could find a kit of a Spruance or a Ticonderoga class ship it would make things soooo much easier. For the SPQ-9 dome i can't find any references on size. I have some pictures but no points to set the size. As for the SPS-52 is its size close to the SPS-49 that Gold Metal Models has? If it is I can use it and hope no one notices.  If I knew that I was going to have this problem 22 years ago I would have gone and asked the guys that worked on these radars this info, I just worked on the AN/SPG-51.
Thanks
    June 2004
Posted by seasick on Friday, June 13, 2014 5:16 PM
According to the Naval institute guide to naval weapons systems 1997-1998 the randome for the AN/SPQ-9A is an oblate spheroid.  Its horizontal axis is 120 inches,  and vertical is 96 inches.
The Diameter of the AN/SPG-51 is 92 inches. The antenna for the AN/SPG-60 was used for the STIR radar on the Oliver Hazard Perry class FFG. The AN/SPS-52 antenna is smaller than the SPS-48. The SPS-48 is 17 feet by 17½ feet.
    July 2004
Posted by stikpusher on Friday, June 13, 2014 6:01 PM
On my box scale (close to 1/300) USS Ramsey kit from Monogram, I had to scratch build a new SPS-52 radar, as the one with the kit is inaccurate. It was very easily made from sheet & strip plastic and some very fine mesh. I have not tackled the  very similar SPG-51completely yet. I have only thinned down the kit dish so far and will add some brass later on.
I have the Dragon 1/350 USS Kidd (Kidd class), USS Ingersoll (Spruance Class), and USS Bunker Hill (Ticonderoga class) in my stash. Do you need measurements of those systems in 1/350 scale (that I can do) or are you looking to pirate those parts (that I will not do) for your build? Those kits are pretty easy to find online. Italeri has also reboxed and released them I believe.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    June 2004
Posted by seasick on Friday, June 13, 2014 11:31 PM
The Radar that shipped with the Monogram USS Ramsey isn't the AN/SPS-52, it is an earlier version of that radar classified as the AN/SPS-39. It was an early 3D air search radar. It's just plain ugly, Monogram didn't mess it up.
    February 2013
Posted by Nikkie51 on Saturday, June 14, 2014 1:17 PM
Thanks,
This will help a lot, Time to think about cutting and scratch building.
    February 2013
Posted by Nikkie51 on Saturday, June 14, 2014 1:25 PM
Thanks -
I found the DML USS Bunker Hill on ebay. I can use the parts as patterns for new ones.  i will rework  the 3D radar to look like the 52.
Thanks for the help
    June 2024
Posted by PaulTK on Wednesday, June 19, 2024 5:54 PM
HS Models makes a 1/350 set of SPQ-9A and SPQ-9B radars.  Part number: HSM U350072S
I'm using a Veteran's Model 1/350 scale radar on a Spruance Class destroyer project.  Part number:  VTM35023
Regarding the SPS-52, check out https://www.shapeways.com/product/NWY6KAF4U/1-100-scale-an-sps-52-radar?optionId=161414470&li=marketplace
If you contact the designer, he might make one for you in 1/350 scale.
