" U " Bootes !
    August 2008
" U " Bootes !
Posted by tankerbuilder on Monday, September 15, 2014 11:23 AM
Ach ! dere is too mush noise about dese here bootes .The best one I've seen is the Big Revell one with All the resin aftermarket insides .
    Ve nust be careful now , the U Bootes must shneak in und invade your verkbench , Ya ! LOL.LOL. I really do like the bigger boats and display the ones under construction in my work area . They would be ,of course the U 47 and such and don't forget the biggest mistake I've made in size , the Seaview !
       I got the large Revell boat and started building the interior using the U 47 as a generic " Go-By" as we say in Wood Carving . It's a very slow process . But I did one thing as a trial and it worked ! I put trimmed down " C.D. " jewel cases on the sides and applied heat , very gently . When they were completely formed over the hull side I removed them
      I did use tightly burnished broiler foil to protect the model underneath . After careful trimming I have clear inserts for the detailed areas . The real trick is to fill the half you want to copy with patching Plaster .It took one, one pound box . Crazy , but it did work . I will say this though . I am not ever going to do that again ! I was lucky once !
Posted by CapnMac82 on Wednesday, September 17, 2014 10:56 PM
Ach du Lieber, iIhre schreckliche Deutsch mein Kopf schmerzte aufmachen.
But, it sounds like a cool build.  Tough part may be in controlling how much pipe & plumbing "clutter" you include.
    April 2004
Posted by Jon_a_its on Thursday, September 18, 2014 8:12 AM
oh ye!
Was fuer katzenjammer!
aber habt Ihr spass damit.
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    August 2008
Posted by tankerbuilder on Thursday, September 18, 2014 8:19 AM
Yeah, CapnMac82;
I know my German sucks ! that's alright though I do have fun . You are right about the clutter and piping in a Sub . If you don't make it look " Busy " it won't look right .     T.B.
    August 2008
Posted by tankerbuilder on Thursday, September 18, 2014 8:20 AM
Aw C'mon ;
  I know Spreken ze englich .Okay ,I'll do that ! He. He.
Posted by CapnMac82 on Sunday, September 21, 2014 4:22 PM
Once my headaches faded 9and getting over could be unter the Plowman, Böotes, other than Virgo), an answer for pipe clutter occurred to me.
Those inenner pressure hulls from that era are of round section, typically.  This could allow a body with an inclination to economy to seek out some PVC or ABS pipe of the right diameter for the pressure hull.  The circular section would make for simpler bulkheads, too.  If a body were supremely luck, the next size smaller pipe would make a form for building between-bulkhead ribs eas(ier), especially with pipe, duct, & conduits fished through.
    August 2008
Posted by tankerbuilder on Monday, September 22, 2014 8:53 AM
You are Right !
 Now couple that with even smaller pipes for the ballast tanks and you would be good to go . On one I did for a friend of my Dad's ( He wanted only the control room) .( in the main hull )  I used a two and one - half inch pipe  .I used the next size down to create the ribs and frames .Worked perfectly ! Good Thinking !   T.B.
