Attaching running rigging blocks to cargo booms on Trumpy 1:350 SS J. O'Brien
    September 2010
Posted by retdfeuerwehr on Thursday, November 13, 2014 6:28 PM
Been working on this for quite some time and haven't found a solution. The cargo boom blocks are difficult to realistically  attach to the booms...the PE fittings for the O'Brien are quite small and difficult to assemble - even if there're only three parts. Trying to superglue the plastic disc between the cheeks of the blocks is an exercise in futility. I'm using a punch and am making my own cargo blocks (a little overscale), but having trouble finding a way to attach them to the booms - I've been using a .010" piece of styrene as the attachment but it's so fragile that even carefully running the cargo whips through them will cause the plastic to break. Hopefully, one can make some sense of this novella and give me a suggestion on how to complete the rigging.
Posted by Don Stauffer on Friday, November 14, 2014 9:26 AM
I tied the blocks to booms using the finest monofilament I had, then painted the thread with same paint I painted the booms.
    December 2005
Posted by onyxman on Saturday, November 15, 2014 8:53 AM
I use fine brass wire glued to the block. Then I use a small pin vise to drill a little hole in the mast and insert the wire into the hole and glue. It gives some spacing between the mast and block. I gave up on that idea of putting a disc between the block halves also. I just folded the halves together and glued them.
Different ship but I used the Liberty PE blocks:
On the Liberty, as on this one, there is no block on the boom end, it's just a single wire attached to the ring on the boom. I didn't rig the wires through the blocks, it goes around the outside ( two step glue process) but the difference is not noticeable after the block is painted. If your booms are lifted, as when working cargo, you'll have the blocks for the running wires, at the head and heel of the booms. That was more complication than I wanted to deal with!
    September 2010
Posted by retdfeuerwehr on Saturday, November 15, 2014 3:33 PM
Excellent idea, sir...I'm definitely going to try it. I've got my Liberty ship with hatches 2 and 4 opened and moving cargo to the pier via yard-and-stay (Burton) method. This will necessitate making two vangs for the booms, plus a schooner guy. I wanted to rig a jumbo boom but the lifting blocks looked a bit too daunting for me. I notice on your model the #3 hatch has a rigged  jumbo boom - how did you do it? From some of the nautical terms you used you sound like you might've been a Boatswain's Mate in another life. Could you send a few more pics of your States Lines model? Thanks again for your helpful suggestion.
    December 2005
Posted by onyxman on Sunday, November 16, 2014 8:34 AM
The jumbo maybe looks more complicated than it is. The boom itself is from a Trumpy JOB kit. So there are blocks at top and bottom, and I just ran wires back and forth between them. By the way, all the rigging on this is 6/O fly tying thread. There is a long story on the forum here on that Victory build:
http://cs.finescale.com/fsm/modeling_subjects/f/7/t/90162.aspx?sort=DESC&pi240=1
Oh, and I had some experience at sea, but mostly as mate on tankers and container ships.
Fred
