Carrier Catapult Question
    November 2008
Posted by plasticjunkie on Monday, November 17, 2014 10:18 AM
I was wondering if using the Italeri 1/72 carrier deck and cat section which is a Nimitz Class be correct to model as the Constellation, that was a Kitty Hawk Class?
I have been comparing some on line pictures of both and appear to me to be very similar.
 GIFMaker.org_jy_Ayj_O
    March 2007
Posted by armornut on Monday, November 17, 2014 12:48 PM
I don't think you'll have a problem, cat systems like many other subsystems are contracted out to a DOD supplier so i don't imagine designs change that often,HOWEVER early Forrestal class and newer did use slings to launch aircraft until late Viet Nam. Most modern jets now use a holdback fitting and a shuttle. If your only showing the area under the aircraft you should be safe.
we're modelers it's what we do
    November 2008
Posted by plasticjunkie on Monday, November 17, 2014 1:13 PM
Thanks armornut. I suspected that but just wanted to confirm.
    March 2005
Posted by TarnShip on Monday, November 17, 2014 1:22 PM
You can use the Italeri or older Verlinden catapult/deck sections for any carrier from Forrestal and up, there are just two things to consider, one is that the carriers older than Nimitz didn't have the "cat bubble" control center sticking up out of the deck. The other is that from Nimitz and later there is a more uniform Hex Pattern to the the tiedowns on the deck. Those were in offset rows on the Kennedy and older. (ship guys can tell the classes apart by looking at the tie down patterns)
As for the bridle system, that was in use from WW II on up to the early units of the Nimitz class, they are on any modern ship's catapults that still have that "horn" sticking out in front (the Van Velm Bridle Arrestor), they had to keep them for a while until all aircraft on deck were of a design with the A-6, E-2, A-7 and later nose gear catapult bar type. So, if you are displaying an A-6, A-7, E-2, C-2, F-18, F-14 or S-3, you use the bar coming out of the front of the nose gear and hooked into the cat shuttle. They also have a hold back cable that goes back to the deck, with a breakable bolt in it.
If you are displaying an F-4, F-8 (and RF-8 on the Nimitz), an RA-5C, A-3, A-4, or older, you need the bridle system and the layout of all of those parts, with a hold back cable.
The shuttle launch and bridle launch gear is all in the "under the aircraft" area,,,,,but, you'll be good if you pick your aircraft wisely.
Rex
almost gone
    November 2008
Posted by plasticjunkie on Monday, November 17, 2014 1:55 PM
Thanks Rex. I will be using the Hasegawa F-14D on this carrier section.
    March 2005
Posted by TarnShip on Monday, November 17, 2014 2:58 PM
if you are going for the moment of launch, or just before that, then all you need is to put the aircraft's launch bar into the cat shuttle, and the hold back cable back to its spot on the deck (the end fits in marked slots next to the cat track)
edit, geez, I am old,,,,,,the "hold back cable" that I talk about is now a "hold back bar",,,,,,but, the idea is still the same, there is a reduced diameter section inside there, that is known to break somewhere above "being able to hold the aircraft back" at Military Power, but,  then to break when the cat pressure is added to the total thrust
almost gone
    March 2005
Posted by TarnShip on Monday, November 17, 2014 3:06 PM
This might be of use for you.
Don't worry, Mr Greenshirt gets out of the way after "doing the hook up check"
almost gone
    November 2008
Posted by plasticjunkie on Monday, November 17, 2014 3:09 PM
Just what I needed, great reference shot . Thanks again Rex!
    March 2005
Posted by TarnShip on Monday, November 17, 2014 3:12 PM
you're welcome
almost gone
    April 2011
Posted by COChef on Sunday, January 25, 2015 12:11 AM
I'm building the same kind of dio but using Dragons 1/144 scale catapult/blast deflector deck section but I'm putting a RA-5C on it with the bridle and hold back cables on it I'm also making the turtle shaped shuttle for the bridle.
I need more infor and pic's of the hold back cable all of the pic's I've found so far are not clear ,I have found that the hold back attaches to just in front of or to the arresting hook but I still don't know how it goes down to the deck and how the cables on the bridle are on the deck exactly I do know where the bridle hooks are on the aircraft so I know how to attach that part of the bridle.
Any help would be great maybe there is an ex Navy Greenshirt on here that remembers how they were setup.
Thank you,
COChef
Camp Lejeune NC
