Lindberg Jolly Roger float test.
    March 2005
Posted by philo426 on Friday, February 27, 2015 7:40 PM
Yeah dudes if you   look closely,the main mast is clearly longer than the foremast.
    March 2005
Posted by philo426 on Wednesday, March 4, 2015 10:02 AM
Further progress.
    March 2005
Posted by philo426 on Saturday, March 7, 2015 12:09 AM
Mounted up the mizzen and rigged the shrouds and the first course of ratlines on the port side.The shrouds are very structural as they stiffen the plastic masts noticeably.
    June 2012
Posted by arnie60 on Saturday, March 7, 2015 1:25 AM
I would like to offer up some hopefully positive and helpful suggestions.
First.
It looks like you are rigging your lines too tightly. You can see this by the slight bow in the main mast. Kits w/ plastic masts and spars are notorious for doing this. Rigging does not need to be so tight that you can pluck it like a guitar string, but just enough to "look" reasonably tight, that is, not sagging. You can get away with much tighter rigging by replacing the masts and spars with wood or brass rod [some go together in two pieces and are hollow in the middle, perfect for reinforcement w/ some brass rod] Plastic gets particularly flimsy when you get to any masts or spars above the top mast. Even lower at smaller scales.
Second.
A good way to ensure that your rat lines come out clean is to first figure out how far apart you want them, then draw horizontal lines on a piece of paper or index card the same distance apart. Place it behind the shrouds and use that as a guide for spacing your rat lines and keeping them level.
There are probably a dozen if not more threads in this forum that go into detail about these things if you want/need more detailed information.
You have not done very much rigging at this point, so going back and loosening a few spots should not be that much work.
Hope this does not sound too critical. I have personally always been very grateful when others here offer up perspectives that have helped me with what I was working on.
That said... I can not wait to see her fully fitted out and afloat. Thats a challenge I am not willing to take on myself.
    March 2005
Posted by philo426 on Saturday, March 7, 2015 8:12 AM
Yes thanks for the tips.My previous rigging on my wooden Sark was different because the wood dowels are much stronger and did not bend.The ratlines need improvement that hopefully I can do better with my next ship model.
    March 2005
Posted by philo426 on Tuesday, March 10, 2015 12:33 PM
I decided to use the vac form sails.I used a microdrill to drill the holes  used to lace the sails onto the yard.I used one long piece of thread to do so.
    September 2012
Posted by GMorrison on Tuesday, March 10, 2015 12:37 PM
Of course you did. Easy way to do it.
    March 2005
Posted by philo426 on Tuesday, March 10, 2015 1:44 PM
Yes it is an effective method.
    March 2005
Posted by philo426 on Wednesday, March 11, 2015 9:35 AM
Lacing up more sails.
    January 2015
Posted by rdiaz on Wednesday, March 11, 2015 11:22 AM
arnie60, I actually have found out smaller scales are more forgiving when it comes to plastic spars bending under tension. Small scale spars are usually a bit over scale in diameter, and since they are shorter than larger ones, they do not bend that much. The jib boom in the Heller Victory, for example, is flimsy as hell and NEEDS replacing, but that of the Revell kit is perfectly straight after being rigged and took quite a bit of tension.
    March 2005
Posted by philo426 on Wednesday, March 11, 2015 12:13 PM
I have found that use of thread to be effective in correcting the warp at the top of the foremast.
    March 2005
Posted by philo426 on Friday, March 13, 2015 10:01 AM
Sewed on the jibs and bow sails.
    March 2005
Posted by philo426 on Sunday, March 15, 2015 10:19 AM
    May 2008
Posted by ejhammer on Sunday, March 15, 2015 11:06 AM
Nice video. Will you do one when you float it? I'm doing a wood kit, a flattie that has been requested to see how it does in the tub. Not sure I want to do that though.
EJ
Completed - 1/525 Round Two Lindberg repop of T2A tanker done as USS MATTAPONI, USS ESSEX 1/700 Hasegawa Dec 1942, USS Yorktown 1/700 Trumpeter 1943. In The Yards - USS ESSEX 1/700 Hasegawa 1945, USS ESSEX 1/700 Dragon 1944, USS ESSEX 1/700 Trumpeter 1945, USS ESSEX 1/540 Revell (vintage) 1962, USS ESSEX 1/350 Trumpeter 1942, USS ESSEX LHD-2 as commissioned, converted from USS Wasp kit Gallery Models. Plus 35 other plastic and wood ship kits.
    March 2005
Posted by philo426 on Sunday, March 15, 2015 12:12 PM
Yes i will!By flattie do you mean aircraft carrier?
    May 2008
Posted by ejhammer on Sunday, March 15, 2015 12:28 PM
Nope, it's a Cheasapeak Bay "flattie", a coastal boat used in the 1900's, to transport goods and fish for clams etc. This is the kit. It's a wood kit. I'm about 75% done with it.  EJ
    March 2005
Posted by philo426 on Sunday, March 15, 2015 2:16 PM
OK!Can you post a pic of it?
    May 2008
Posted by ejhammer on Sunday, March 15, 2015 5:26 PM
Here you go Phil, This is a plank on frame build. The do-da's in front are the centerboard, rudder, gunnel trim, mast and booms, all ready to be installed yet. Then the rigging and a bit of dressing, rope coils and other trappings of a working oyster boat. I boogered the deck stain yesterday by spilling a bit of clear gloss on it. Instead of letting it dry and sanding the lump down, I tried to wipe it off, therby removing the layer of Vallejo matt clear and the wiped stain under it back to the white base. Crap. I might have to cover it with a crate or a lobster pot or something. Anyway, it's been a fun little wood kit to build. I like these to space in between regular plastic kit builds as it takes me a year to to an aircraft carrier. Here she is at present. Should have her done in a week or so.  EJ
Posted by CapnMac82 on Sunday, March 15, 2015 6:25 PM
Did I read the scale o nthe box right, and that's 3/8" = 1'-0" ?  This can be a great scale to work in with the Midwest kits.
    March 2005
Posted by philo426 on Sunday, March 15, 2015 6:44 PM
Looks really good!
    May 2008
Posted by ejhammer on Sunday, March 15, 2015 6:50 PM
Thanks guys. I like the wood kits, especially the boats, like the flattie, Titanic lifeboat, Lobster smak and skiff. They are quick to put together, plus, having been a builing contractor and carpenter most of my life, working wood just seems to come natural. Plus, they are a 'change up" from plastic kits so I don't get bored.
EJ
    March 2005
Posted by philo426 on Friday, March 20, 2015 12:39 AM
Finished up the rigging but the float test did not go well!The ship either listed to port or starboard and the addition of lead shot only caused water to pour in and sinkit!I guess it will have to remain in dry dock display!
    September 2012
Posted by GMorrison on Friday, March 20, 2015 3:25 PM
IF you ever decide to try a floater again, three things.
1. There's no point in ballasting the hull ahead of time. As you foud out, it can create all kinds of fit problems later. And you couldn't accurately predict the final weight of the model.
2. All of the mast gear weighs so much more in comparison to that hull, that you created an artificially high center of gravity. So it tips over.
3. The only way to make a pond sailer reliable is to have an artificial keel. Well maybe not the only way, but certainly the most reliable and practical way. If I were to do it, I would have put a downward pointing keel dead center front to back, 2" fore/aft in width and 12" or 2/3 the height of the masts downward length. Something fairly rigid like a piece of 18 gage aluminum.
Set it in the pond, and assuming it doesn't immediately sink, clamp a small weight on the bottom end of the keel. Then adjust the amount of weight until the waterline is where you want it, with a margin of safety.
Then try moving the weight up the keel, testing its stability as you go. When you get to a comfortable point, stable but a little soft as far as heeling, clamp it permanently, cut off the remaining aluminum and paint it all black.
Thats how I do my pond sailboats.
    March 2005
Posted by philo426 on Friday, March 20, 2015 5:12 PM
Makes you wonder how the real ships were ballasted.Who would have thought the plastic masts ,yards and rigging would add up to throw the balance off so radically !
    September 2012
Posted by GMorrison on Friday, March 20, 2015 5:29 PM
You know the saying "scale doesn't fly".
We can add the saying "scale don't float".
    March 2005
Posted by philo426 on Friday, March 20, 2015 7:16 PM
I wonder if I can ballast my 1/600 Titanic or wold it dot he same thing?
    August 2008
Posted by tankerbuilder on Monday, March 23, 2015 4:47 PM
Proff.
I do have to agree with you . I built one of these as a gift and the lowest flange on the foremast is supposed to be sitting right on the deck ! I would worry about that height , definitely .
    August 2008
Posted by tankerbuilder on Monday, March 23, 2015 4:59 PM
Philo426
    The real ships were ballasted mostly with a stone that was chosen for the job . Round smooth river stones .Then the Cannon Balls not on deck and Most of the stores and powder as well as spare mast parts and spars were carried well even with or below the water line .
   Even the addition of her rig and guns were taken into account . I think some of those boys back then knew about how much the bare ship weighed too ! When I did my " Constitution " in Cal . I had a two and a half inch false bottom on her ( outside ) to allow for the weight and masts .The keel was about four pounds total and hidden by the false bottom .           T,B.
    March 2005
Posted by philo426 on Monday, March 23, 2015 5:41 PM
Wow!4 pounds!
    September 2012
Posted by GMorrison on Monday, March 23, 2015 6:01 PM
NNNggghhhh...
About the only thing you can do is hope to replicate the vertical center of gravity- in every other way scale will defeat you because for every increase in a given dimension, the mass increase is a cube.
I'd guess the center of gravity on that ship was well below the waterline.
But getting to that waterline is the trick. In addition to whatever mass you need to get the CG low, you also need mass to displace the water. I can't guess the displacement volume to the waterline of that model, but let's say it's 24 cubic inches- 12" x 2" x 1'". A cubic inch of water weighs about 0.6 ounces (did the math).
So the displaced weight is 14 ounces, almost a pound. And that all has to be below the waterline along with whatever you need to account for everything above the waterline.
That gets you to the tipping point.
Thats all I wish to contribute.
