!/200 DKM Tsingtau
    September 2010
!/200 DKM Tsingtau
Posted by retdfeuerwehr on Wednesday, March 11, 2015 9:33 PM
Been working on a scratchbuilt model of the Schnellboot tender "Tsingtau" in 1/200 scale. Have used Balsa-Foam for the hull and using styrene for other components. Question is: the hull has been formed and I used Spackle to fill in certain spots. Now I need to coat the hull prior to painting....how should I prepare the surface...I'd like to use EnviroTech two-part epoxy but have no experience with it. Can anyone give me some tips on using the EnviroTech for this purpose?
    September 2005
Posted by freem on Wednesday, March 11, 2015 9:56 PM
EnviroTech is a super think epoxy varnish that is mixed together and then usually poured on to the surface. Countertops, table tops and different shaped clocks are the main places it's used.  I am not certain that it would be the product I would use in this case.  I think it would be too glossy to handle paint, would not sand easily, and be way too thick (when poured it's like 50 coats of polyurethane.  It would however be super smooth.
Sanding sealer either alkyd or water based would probably be a better choice, or model airplane dope. As I'm sure you are aware the object is to eliminate the wood grain.
Chris Christenson
    September 2012
Posted by GMorrison on Wednesday, March 11, 2015 11:01 PM
So Freem, Balsa Foam is a foam product, expanded cell phenolic.
Red,
I've found the best finish to be Acrylic Modeling Paste, which you can get at the art store. Blick sells it, so does Aarons. It's like Acrylic Gel Medium, but a little harder.Sands well, takes paint, not smelly.
    August 2005
Posted by EdGrune on Thursday, March 12, 2015 6:02 AM
I think I would go with Bondo auto body filler
Its available at Auto supply shops (Pep Boys, Auto Zone, O'Reillys)  and at WalMart,  Lowes, Home Depot.
Mix it up,  lay on a skim coat, and you should be able to sand in less than a half hour.   Repeat as necessary to fair everything togheter.    Bondo smooths and featehrs well.    Other Bondo products are available to fill any remaining cracks and pin holes.
    September 2012
Posted by GMorrison on Thursday, March 12, 2015 4:11 PM
Also a good choice. Wasn't there a member named Bondo?
    August 2005
Posted by EdGrune on Thursday, March 12, 2015 7:27 PM
Phil "Bondo" Brandt was an excellent modeler out of Austin Texas.    Phil preferred "difficult" kits and Bondo was his weapon of choice in his projects.    Phil's was a fixture on Hyperscale.    Phil passed a couple of years ago while on vacation in Europe,
