display
    October 2004
display
Posted by ikar01 on Tuesday, July 7, 2015 7:25 PM
I just started a 1/700th model of the Destroyer Reuben James. What would be a good way to display this waterline model?
Posted by Don Stauffer on Wednesday, July 8, 2015 9:07 AM
Waterline models pretty much require a sea/water base.  There are lots of options for this.  In 1:700 I can often make waves in a fairly thick blue paint with hand brushing, using several coats.  Then several coats of clear gloss.  When brushing, put down thicker application on each coat over crest of waves.
Other options include krinkled aluminum foil smoothed back out and glued to wood base, wavy plastic, or model railroad water.  Artist gel medium (thick) is also used to make water.
    September 2012
Posted by GMorrison on Wednesday, July 8, 2015 9:50 AM
The thing is not to try to make the water "see through". It's not realistic. Don suggested one easy way- paint the board a blue-greenocean color, and paint on acrylic gel medium. It's pretty cheap at Aaron's and comes in several gooiness levels. Kind of like cold cream, dries clear and shiny, or matte if you buy that one.
    September 2012
Posted by GMorrison on Wednesday, July 8, 2015 9:52 AM
If she is under way and you want a wake, find a photo of either that ship/ class or something like it and carefully copy what you see. You can put white acrylic paint in the gel medium for that.
    September 2012
Posted by GMorrison on Wednesday, July 8, 2015 9:56 AM
Out of curiosity, the Clemson, Buckley or Perry class?
    October 2004
Posted by ikar01 on Thursday, July 9, 2015 5:19 AM
It's a Clemson class.  I would have preferred a larger size and maybe a full hull but the choices are limited.
Here's  the song about her.  The second one shows the ship.
www.youtube.com/watch
This one shows pictures and drawings from the time, even the newspaper story:
    November 2003
Posted by Mike F6F on Tuesday, July 14, 2015 11:37 AM
cs.finescale.com/.../107532.aspx
Here's a post from several years ago of one of my 1/720th scale carrier models.  In it we have a discussion regarding mounting waterline ship models to a plain, black base and does it work.
It is my preferred way of doing small scale waterline models.  It is direct and simple and as you can catch from the attached posts others acknowledge it as a excellent option to modeling  a sea.
A well done sea can enhance a model.  A poorly done one can hurt a well done model.
In my experience, casual model observers become so excited about the modeled wave action, etc., that they can miss the model ship entirely.
"Grumman on a Navy Airplane is like Sterling on Silver."
    September 2006
Posted by the Baron on Tuesday, July 14, 2015 11:50 AM
You can use silicone caulk to make an ocean surface, too.
    October 2004
Posted by ikar01 on Thursday, July 16, 2015 11:19 PM
I like the idea of the black base for the Reuben James.  That 4 stacker is only about 4 inches long.  It looks so small it could be easily overpowered by moving water.
I do have a couple other ships what I can display on waves or in a couple civil war cases a muddy river.  I'm thinking of having one fighting the current at a fork in the river as it makes a turn.  That way there will be a bit of foam off the bow in one direction and the stern in the opposite direction
    December 2005
Posted by onyxman on Friday, July 17, 2015 11:31 AM
You can go to an art  framing store and buy paper matte board in any color you like. It comes with a little texture that "suggests" water, but doesn't distract from the model. In my opinion the absolute worst idea is the crinkled tin foil method. It is a very accurate representation of crinkled tin foil, and I've never seen an ocean surface that looks like that.
Fred
Posted by Don Stauffer on Sunday, July 19, 2015 12:50 PM
onyxman
Fred
You have to be careful how you wrinkle it.  The wrinkles, representing wave crests, should be basically parallel, but not perfectly so.  I roll the foil first, then crush the cylinder to put the wrinkles in it.  They should be then flattened carefully, and much of the art is in the painting.
    September 2009
Posted by Felix C. on Sunday, July 19, 2015 1:02 PM
If it is not a diorama I would purchase a good thick piece of either azur blue glass or green glass and just use that. You can also get very dark grey, almost black glass known as turtle glass. Really an inexpensive way to display waterline.
    October 2004
Posted by ikar01 on Sunday, July 19, 2015 8:25 PM
Where would you go to buy this glass?
    September 2009
Posted by Felix C. on Monday, July 20, 2015 4:33 AM
I worked at a commercial glass company and that is where I secured mine. Cardinal, PPG, etc. But they do not sell direct.Have to purchase from a distributor
    September 2005
Posted by warshipguy on Monday, July 20, 2015 8:21 AM
I read an interesting technique for making a water base for waterline models in the Bluejacket newsletter about a year ago.  As mentioned here, you start with some medium like blue paint, plaster, or other, applying it in layers as you work, painting it as seen in photos. However, the article pointed out that you use your fingers in the wet medium to form the waves. Simply place your fingers palm down where you want the waves, spacing each finger as desired and slide the fingers off of the edge away from the ship. Repeat on the other side of the ship.  It is simple to do, and  it will look quite good.
Bill
    August 2006
Posted by Dr. Hu on Thursday, July 23, 2015 8:20 PM
I recall an article quite a few yeas ago that used a sheet of suspended ceiling light panel. They used the stuff that has a textured face on one side and smooth on the other. they spray painted the rough side with some white paint where you wanted to show the wake and the wave tops then blue, turned it over and you had flat smooth surface to place the model on.  It looked good in the magazine. I may still have the maga but it would take some searching. It looked surprisingly good.
Doc Hu
    December 2005
Posted by onyxman on Friday, July 24, 2015 11:22 AM
The main thing to remember is that at any scale that ship models are usually done in, you cannot see through the water surface. It's pretty opaque.
