USS Nassau 1:720 build thread
    June 2015
Posted by Fireblade910 on Tuesday, August 4, 2015 10:31 AM
Ok, finally dove in. After a month or so researching and collecting the parts I need, construction has begun on this beaut. I'm actually shocked at how low the quality of the plastic is on this Model. I've not modeled ships in about 20 years, but this seems like the worst kit quality-wise I've seen from Revell! The sprues are so thick going into the pieces that there will be significant sanding required! If I were an amateur I'd likely not stay in the hobby long with a model this lacking in quality. This model will reflect the MARG 4-87 (Marine Amphibious Readiness Group)tour to the Mediterranean that my Uncle served on in 1987. VMA-231 and HMM-264 were the two marine units assigned at the time, and will be reflected on the aircraft paint schemes of the time. So! On to the good stuff, and this is just a quick post. The Keel has been laid! Was late last night, but I will start sanding down the hull next and start working on the interior portion of the lower deck where the elevator is. This will be a super-detailed effort, and I am intending on building the details to any visible portion of the inside as best as I can. I also will be picking up some CH-46s and Harriers from the hobby shop tonight.
    September 2012
Posted by GMorrison on Tuesday, August 4, 2015 11:29 AM
I would like to make a couple of suggestions. Since you have the ambition to create a fine and detailed model, you should put this kit aside and go with the Dragon kit. It has a lot of fine reviews, it no doubt has a lot more detail, and I don't think you will have any problems with the plastic. From a lot of experience, I've learned that after several hundred hours of time spent on something, it is best to not handicap yourself out of the gate.
You had said in the other thread that you were going to practice on a cheapo model. I assumed the Revell kit was it. Now it sounds like the time and effort, and $$$ for all the aftermarket, is going to be focused here. I wouldn't do that.
The Dragon kit has the CH-46, sorry no Harriers.
The other thing, the glue there is designed to bond stuff like ABS, poly, and styrene together. I use it on architectural models, but it leaves a film. You should use a styrene to styrene glue. I like Testors, Tenax.
    June 2015
Posted by Fireblade910 on Tuesday, August 4, 2015 12:29 PM
Thanks for the heads up. I use Plastruct glue, I've never been a fan of the Testors stuff. I have some intermediate experience gluing styrene and plastic together.
With your other suggestion, I went and found another Dragon kit on ebay. The problem with them is that they have usually run for a good chunk of change, more than I am willing to spend. Before I commit the good money parts on this Revell, I will try for another time on the Dragon kit. I can still make the Revell kit work, as I do have good experience with super detailing stuff, and the only detail issue I see that I can't fix is the oversized molding on the superstructure. Other than that, this kit will just require some extra time with careful sanding and shaping.
    June 2015
If I do end up with the Dragon kit, I'll use the Revell kit to practice paint shading and coloring
    March 2004
Posted by Mikeym_us on Wednesday, September 30, 2015 8:23 PM
GMorrison
G the later issues of the Tarawa class do contain Harriers. The Dragon/Italeri USS Nassau has the Harrier sprue.
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    September 2012
Posted by GMorrison on Wednesday, September 30, 2015 9:34 PM
Good to know, I picked up the Trumpeter set.
    September 2012
Posted by GMorrison on Wednesday, September 30, 2015 10:31 PM
910 I'm eager to see you get the model built. My Dragon kit has not been real great so far. I have a thread on it.
I really like the subject though, and it'll be fun for you if you stick it out.
    March 2009
Posted by surfsup on Thursday, October 1, 2015 1:42 AM
I like the idea of using the Revell Kit as a test and building the DRagon Kit. It has better detail. I built it once before and wss not as bas as the Revell kit. I agree the Dragon Kit has a few issues but nothing like the Revell Kit. But in the end, the choice is yours.....Cheers mark
If i was your wife, i'd poison your tea! If Iwas your husband, I would drink it! WINSTON CHURCHILL
    March 2004
Posted by Mikeym_us on Thursday, October 1, 2015 10:19 PM
Really Trumpeter finally released the 1/700 scale aircraft sets for the Gallery LHD's?
