PE rigging
PE rigging
Posted by Don Stauffer on Tuesday, November 10, 2015 9:24 AM
At the last Omaha nat show, I bought a piece of PE with sets of shrouds/ratlines on it.  That really looks great on small scale sailing ships!  I used some on the 350th Cutty Sark.  Just found, when restacking some of my stash, a 1:600 Victory.  Hope I can find enough pieces on the fret to do that ship.
I guess the disfavor of smaller scale sail these days probably discourages PE companies from doing more of that.  I am afraid when I use up the current set I will be unable to find anything like that again, or are enough folks doing it that I will be able to find some?
    September 2012
Posted by GMorrison on Tuesday, November 10, 2015 10:02 AM
My only experience with that was the rear mast ratlines on the aftermarket set for the Revell Emden.
A thought- one thing I sort of disliked was the fact that the horizontals and verticals were the same size, big, and it looked kind of like a grating.
The last 1/350 I did with PE, for the lifelines around the main deck, which generally get paintied like bar railing even though they usually aren't; I painted the things a light gray sort of wire/ weathered rope color, and then painted the vertical stanchions ship blue. It was pretty easy because a) the stanchions were really short, and b) I did it by dipping the edge of a single edged razor blade in a little puddle of blue and "stamping" the stanchion.
Maybe you can try that. Paint the ratline/ shroud part the lighter ratline color, and then paint the shrouds only black with the edge of a razor.
Posted by Don Stauffer on Wednesday, November 11, 2015 9:28 AM
That is a good idea, though I wonder if black may not be self defeating.  On something very small, near eye resolution, contrast has a big bearing on size estimation, and high contrast makes things look bigger than they really are. I wonder if reversing the colors might work too.  I always avoid strictly black or white in rigging lines if I can find a tan or dark gray.
    December 2013
Posted by chango on Sunday, November 22, 2015 9:49 AM
Not Age of Sail stuff but I've noticed pontos aftermarket sets keep sneaking more and more pe rigging into them, which is great in my opinion.
I really wish the plastic market would give us more "tall ships" and that aftermarket companies would put out superdetail sets for the ones we've got.
